-   -   Difference in Futaba Rx's (https://www.rctech.net/forum/radio-electronics/303654-difference-futaba-rxs.html)
piranha21 06-10-2009 06:09 AM
What is the difference between the 603FF (89.99) and the 603FS (99.99)?
Duster_360 06-10-2009 06:24 AM
603FF has dual - internal/external antennas, it detects whether HRS or PPM is active from tx and adjusts accordingly and has a fail safe for low rx voltage.
603FF has only the external antenna. Looks like its only available in 3 channels.
Cpt.America 06-10-2009 08:24 AM
That clears that up I guess... :cool:
Rick Vessell 06-10-2009 09:38 AM
FS is dual antenna
FF is single antenna
FS switches automatically between PPM and HRS when detected.
There is no built in F/S for either receiver. You're still dependent on setting the F/S settings in your TX which the RX defaults to if it loses signal. If you run low on voltage or lose battery there is nothing to power the RX to maintain the F/S.
Cpt.America 06-10-2009 11:55 AM
FYI, you can get the FS (dual antenna) from stormerhobbies.com for $89
Duster_360 06-10-2009 12:07 PM
http://www.futabarc.com/radioaccys/futl8926.html
