Tamiya TB-Evolution III
#4816
thanx steevo!
#4817
Who's got the Tech Racing 3 piece shaft set? If you have one, please do comment. There is a pic here.
OH...found the image.
#4818
I have been told that the next shipment of Tech Racing 3 piece shafts will be the last. It has been discontinued and they are extremely hard to get.
#4819
It's already almost impossible to get them now, and the fact that they are gonna discountinue it, that just makes it even harder to get.
I've been trying to purchase some red main drive shafts from all over the world and Tamiya themselves...but no luck so far. Anyone knows where to get one?
#4823
#4824
tech racing not only make a 3 piece but also a normal red prop.
check that out
also
Carbon 3 piece prop in the making
Tarnjit
check that out
also
Tarnjit
#4825
i need a hand,
i still havent replaced the crappy servo saver that comes with the kit . i had a question about it though, how you you keep it closed? once built if i put it on the servo the top bit can still come off even when the screw is done up?
any ideas
if not im just gonna use a longer screw and put a big washer on the end...
Tarnjit
any ideas
Tarnjit
#4826
I didn't even try with the standard screw - I used one of the titanium screws that came with the Surikarn.
Cheers, Mark.
Cheers, Mark.
#4827
JUST BLOOODY REALISED THAT I NEVER PUT THE UPPER DISK ON THE SERVO SAVER! IVE BEEN USEING IT FOR MONTHS WITHOUT IT ... SHOOT ME NOW
#4828
Best is replacing the servosaver with a Kimborough KB201. No play at all and no problems.
#4829
i ordered one and it was meant to arrive in time for my race tommorrow but me attracting al the back luck in the world.... the shop made a mistake with the package so i must do with the tamiya one for now
#4830
should work now with that upper disk but try getting the KB201. no play and centers much better. But you have to use the outer hole on the KB.
