fuel questions...
Old 06-05-2009 | 07:57 AM
-_-
Default fuel questions...
anyone try before using gasoline in their nitro engine? whats is the outcome? and is there any different between the nitro airplane fuel and nitro car fuel? Thanks!
-_- is offline
Old 06-05-2009 | 08:25 AM
airplane fuel is made to run with less oxygen and has more oil, you only want to run surface nitro fuel for your car.
Brian Bosley is offline
Old 06-05-2009 | 08:34 AM
rcrevolution's Avatar
gasoline doesnt have the proper lubricants to keep a nitro engine running, thats one issue
rcrevolution is offline
Old 06-05-2009 | 11:49 AM
nazwenhome's Avatar
i dont think it'll burn easily even during idle stick with the manufactures recommendation.
nazwenhome is offline
Old 06-05-2009 | 12:00 PM
wingracer's Avatar
Gasoline has too low an octane rating so detonation would be a huge problem. It would make less power. Also, it would probably destroy all the seals in the engine. Seals for gas and alcohol are made from different materials.
wingracer is offline
Old 06-05-2009 | 12:08 PM
nazwenhome's Avatar
i did some research on nitro engines using gasoline few years back. need to mod something and add some electrical timing jargon and maybe some fuel regulator to make it happen.
Old 06-05-2009 | 07:26 PM
-_-
oic... Thanks everyone for the input... im just curious so ask about whats the different...
-_- is offline
