Mugen JX21
Old 05-28-2009 | 10:23 AM
  #511
Originally Posted by TonysScrews
The original C-Type header (JX14001) was discontinued by Mugen. They now only stock the L-Type (JX14002) and the C-Type MBX6-80 (JX14005) headers. The original C-Type was the same as the OEM curved header on the OS 2050/2060 pipes. Mugen discontinued it because the new MBX6-80 header is only 80mm wide so it tucks the pipe in closer to the engine on the tight, narrow MBX6 buggy (helps keep weight to the center of the chassis as teh MBX6 buggy is heavier on the motor side). All three headers with the JX pipe (JX15001) fit the MBX6 though.
I still have one of the original C-Type (JX14001) headers still in stock. It's probably the last one out there...LOL
They have got both on Amainhobbies.com. what is the difference between them?
Zach Phillips is offline
Old 05-28-2009 | 02:41 PM
  #512
smracer31's Avatar
Has anyone tried the new torco fuel in there jx or v-spec? looking for some feedback before i buy some 30%
smracer31 is offline
Old 05-31-2009 | 08:29 PM
  #513
TonysScrews's Avatar
TonysScrews is offline
Old 05-31-2009 | 08:53 PM
  #514
Oh...FYI
EB Mod head buttons and lightened JX-21 connecting rods are back in stock.
We also have JX-21 piston & sleeve sets, stock rods, and carb inserts back in stock as well.
Old 05-31-2009 | 09:07 PM
  #515
Thanks but I would also like to know what the difference between them is in performance. Like th longer the header the more or less bottom or top? the shorter the header the more or less bottom or top?
Old 05-31-2009 | 09:41 PM
  #516
We only tested the JX14001 and JX14002 because the JX14005 wasn't available at the time. The RED line is the L-Type Header (JX14002) and the GREEN line is the C-Type Header (JX14001)
Old 05-31-2009 | 09:55 PM
  #517
GREGORY!'s Avatar
Tony have you noticed any diff in the run time?
GREGORY! is offline
Old 05-31-2009 | 10:03 PM
  #518
jpalessi's Avatar
YES! the L shape header gets a lil better RT. maybe 30-45 secs
jpalessi is offline
Old 06-01-2009 | 06:22 PM
  #519
reggie l.'s Avatar
i hear the ae 2035 is good for this i have one i havent ran it yet.. but how does this pipe compair to the 2060?
reggie l. is offline
Old 06-02-2009 | 04:56 PM
  #520
reggie l.'s Avatar
got my ebmods button today realy had to take out the calipers to see the difference between the stock and eb
Old 06-02-2009 | 05:04 PM
  #521
ezveedub's Avatar
I could tell just looking at it the difference.
ezveedub is offline
Old 06-02-2009 | 05:19 PM
  #522
reggie l.'s Avatar
i thought it was goin to be cuts or somthing in the button..but it look like he just changed the depth..creating more compression
Old 06-02-2009 | 05:53 PM
  #523
jpalessi's Avatar
ya ok
nah the compression is the same, just the squish band is changed. Most of Ed's mods can't be seen and/or go easily unnoticed. We've had ppl call in saying this engine isn't modded... Make sure you only use the one shim supplied in the kit. Chuck the stock shims. On the stock button the aluminum shim can go unnoticed because it stick to the button. you may need a razor to lift it off the button.
jpalessi is offline
Old 06-02-2009 | 06:20 PM
  #524
reggie l.'s Avatar
yea man i just took it out the pack and measured it and put it on so the shim thats on it is wats in the motor now...i didnt know just that much change in squash would make that much power
Old 06-02-2009 | 08:26 PM
  #525
Jason Pelletier's Avatar
When are these engines going to be available again ?
Jason Pelletier is offline
