Mugen JX21
Old 06-02-2009 | 08:54 PM
  #526
What size shim comes in the package ?
Chris Reilly is offline
Old 06-02-2009 | 09:35 PM
  #527
jpalessi's Avatar
.004
jpalessi is offline
Old 06-03-2009 | 06:15 AM
  #528
will a speed piston ,sleeve and rod work in a jx
james
jlo8864 is offline
Old 06-03-2009 | 06:57 AM
  #529
jaylude22's Avatar
james
Yes.
jaylude22 is offline
Old 06-03-2009 | 08:31 AM
  #530
thuren's Avatar
Originally Posted by ezveedub
I could tell just looking at it the difference.
Me too... It is very apparent the slight taper is taken off the outer edge of the combustion chamber. Surely there is more magic than that but you can "see" it..
thuren is offline
Old 06-03-2009 | 08:33 AM
  #531
thuren's Avatar
Running the EB head button, should I play with gasket thicknesses at all? What would I gain/loose if anything?
thuren is offline
Old 06-03-2009 | 08:36 AM
  #532
reggie l.'s Avatar
yea i could see that too..but i was talking about the squash..something told me the taper wasnt the only thing done
reggie l. is offline
Old 06-03-2009 | 08:37 AM
  #533
reggie l.'s Avatar
just run the shim that came with it and you will be fine
Old 06-03-2009 | 08:39 AM
  #534
jpalessi's Avatar
It's funny how you guys seem to think you can see it, but i have seen even Ed grab calipers to tell the difference. So idk maybe you guys have some super vision.
No !Do NOT play with shims at all. you'll either lose power or blow up your engine.
jpalessi is offline
Old 06-03-2009 | 08:44 AM
  #535
reggie l.'s Avatar
if you feel the top of the button at the same time as the stock you can feel a slight edge to the stock vs the eb..other than that i had to take the calipers out...expecilly to make sure wat i was feeling right..and to cheak the squash
Old 06-03-2009 | 08:46 AM
  #536
thuren's Avatar
I don't think I would like to spending hours sorting stock buttons vs. Ed's, as my brain would explode. but I could see it, I think. lol!
So just verify I have a .004" shim in there and call it perfect yes?
Thanks!
thuren is offline
Old 06-03-2009 | 09:32 AM
  #537
jpalessi's Avatar
Thanks!
Yes. .004 is perfect.
jpalessi is offline
Old 06-03-2009 | 09:56 AM
  #538
ezveedub's Avatar
Simply put, stock O.S. head buttons have very little squish band area. The EB button has the taper milled away, similar to Novarossi head buttons. By doing this, the head button now sits further away from the piston. Ed supplies the correct gasket to bring the head button closer and obtain the correct clearance with larger, more effective squish. If you taken plenty of O.S. engines apart, you would be able to know what is different, but then again, most people can't tell if head shims are installed or not.
ezveedub is offline
Old 06-03-2009 | 10:05 AM
  #539
jpalessi's Avatar
well said.
jpalessi is offline
Old 06-13-2009 | 07:41 PM
  #540
jwcobra03's Avatar
Looking for a used carb for this motor, if anyone has one and looking to sell pm me.
jwcobra03 is offline
