8T 2.0
Old 04-30-2009 | 08:44 AM
  #2176
jldjlaudio's Avatar
I have the TOP TOP plate LOL but the part your talking about is the top servo save part itself in aluminum??
jldjlaudio is offline
Old 04-30-2009 | 08:46 AM
  #2177
jldjlaudio's Avatar
You talking about this one http://cgi.ebay.com/LOSI-LOSA4441-AL...3%3A1|294%3A50
I have this one already http://cgi.ebay.com/team-losi-8ight-...3%3A1|294%3A50
Old 04-30-2009 | 08:49 AM
  #2178
JAMMINKRAZY's Avatar
Originally Posted by jldjlaudio
That is the 1.0 version.
This is what I am talking about.
http://carolinasrc.com/Webstore/Scri...dproduct=11579
Or this
http://carolinasrc.com/Webstore/Scri...dproduct=12616
JAMMINKRAZY is offline
Old 04-30-2009 | 03:03 PM
  #2179
teeforb's Avatar
my entire steering system is completely stiff!!! now i have to figure out what's causing it!!! i hate doing this...
teeforb is offline
Old 04-30-2009 | 03:06 PM
  #2180
ZERTA RACING's Avatar
just let me have the car and i will give you mine my steering is lose.
ZERTA RACING is offline
Old 04-30-2009 | 05:28 PM
  #2181
Integra's Avatar
once the cam get's dirty the action is very rough and needs attention...if your using the 2.0 spring Ditch it and use the 1.0.
Integra is offline
Old 04-30-2009 | 05:41 PM
  #2182
The 2.0 spring works perfectly fine. You just have to set it differently(not as tight). The spring is not the problem, it is the factory settings and a bad run of plastics that caused the problem. The plastics were molded incorrectly. The cup for the spring was molded too small and forcing the spring into it caused them to break. I have been using a properly set 2.0 spring in both my 2.0 buggy and 2.0 truggy without one single issue.
Old 04-30-2009 | 05:51 PM
  #2183
Integra's Avatar
IMO the spring is too tight....why would they be testing a new spring if the original wasn't a problem ?
Integra is offline
Old 04-30-2009 | 06:29 PM
  #2184
wb-racer-ace's Avatar
hey guys, just finished up some new carbon fiber towers for the 1.0/2.0T
They are cut from boeing aircraft grade carbon fiber, 5mm thick. shock and camber link holes are 2.0 spec with 2.0 and 1.0 body mount holes.
weight's are front:.7oz/21g, rear:1oz/28g
stock 2.0T tower weights are front:1oz/29g, rear:1.3oz/38g
prices are $30 each for front or rear shipped in the us. overseas shipping add $15
Attached Thumbnails 8T 2.0-2.0tfront2-600-x-451-.jpg   8T 2.0-2.0tfront-600-x-451-.jpg   8T 2.0-2.0trear2-600-x-451-.jpg   8T 2.0-2.0trear-600-x-451-.jpg
wb-racer-ace is offline
Old 04-30-2009 | 06:32 PM
  #2185
PIMP_9000's Avatar
Originally Posted by Toiffel
OK, having serious flasbacks here, the screws holding the bottom of the rear shocks are backing out, anyone have a fix?? On my 1.0 used a longer screw and a locknut....any ideas??
Use x ray screws the lh thread ones prob gone.
PIMP_9000 is offline
Old 04-30-2009 | 08:52 PM
  #2186
Frank L's Avatar
Those look cool but I am not a fan of carbon fiber for shock towers as I have broken King Headz alum towers before. But nice work.
Frank L is offline
Old 04-30-2009 | 09:16 PM
  #2187
It's not too tight if you set it properly. Like I said mine both have the 2.0 spring and I have plenty of "saving". You just have to set it alot looser than you are used to. Not really sure why they would test a new spring. I guess so you can set it tighter and still actually have a servo saver.
Old 04-30-2009 | 09:32 PM
  #2188
steve307b's Avatar
Hey guys does anyone know the website for the guy who painted the Nemo 2.0 body? I remember looking at some of his other work from a link on here but cant remember what page. Thanks
steve307b is offline
Old 04-30-2009 | 09:43 PM
  #2189
RcRick's Avatar
I agree Jammin,I am running the stock servo saver on both my 2.0 Buggy and 2.0Truggy with zero problems,about 4 gals on the Buggy and about 2 gal.on the Truggy,Just backed off the spring from the fact.settings as you said.
Rick M.
______________
TeamLosi
O.S.
Byrons
Hitec
Panther
RcRick is offline
Old 05-01-2009 | 12:02 AM
  #2190
If the 2 screws in your bellcrank posts are too tight it will bind the steering. Those are the back 2 screws in your top plate.....
LosiMadMan is offline
