Corally Phi Thread
Old 03-29-2009 | 10:49 PM
  #316
B4james's Avatar
I Had an Excellent result on the weekend at the Harris RC Classic in Bendigo VIC.
There was two full heats of stock and as far as I'm aware I was the only person to run brushed in the A Final.
I TQ'd and won the stock class and managed to also set the fastest lap and race times.
There were 3 finals and all finals counted, the PHI ran fantastic and did not let me down once over the whole weekend. The car was fast and excellent on its tires across every race in hot conditions.
Can't wait for the new car
B4james is offline
Old 03-30-2009 | 07:21 PM
  #317
B4james's Avatar
I have had a couple of people PM me asking on my set up,
I ran exactly the same as Ari's Summernats 09 set up but with the below changes:
Springs - Front 22lbs , Rear 19lbs
No sway bars front or rear
Standard kit hexes and hubs front and rear
Specialised RC Lipo tray with all weight on the inside holes of tray to bring up to legal weight. Much more 24 & 32 Absolute tires with V Made accute and Sweep Z1 traction compounds depending on time of day.
Air temps were in the high 20's with the Sunday being 29 so track was reasonably warm.
B4james is offline
Old 03-31-2009 | 06:29 PM
  #318
Originally Posted by OLD 69
Hey guys here's my Setup from the '09 SummerNats
Ari,
What size spacers were you running on the rear hubs and new style steering block for this setup?
Matt
kingpops is offline
Old 03-31-2009 | 07:20 PM
  #319
OLD 69's Avatar
Company Representative
Originally Posted by kingpops
Ari,
Matt
Matt, i was running the ball studs # TC79263 with a 2mm washer underneath.
...Ari
OLD 69 is offline
Old 04-07-2009 | 06:21 AM
  #320
A Ilievski's Avatar
Well round 2 of challenge cup has been run and won...
Ended up finishing 4th in the A's. The car was awesome all weekend but due to tyre errors and some mind blanks on my behalf ended up 4th. The car was dialed and up to pace. Clearly noticeable of the speed difference especially off the start down the straight .
I will be buying the new steering column and having a play with that and see how i find it.
NSW titles in 3 weeks time, whos entering?
A Ilievski is offline
Old 04-09-2009 | 09:47 PM
  #321
A Ilievski's Avatar
Im looking for the 36T front and diff pulley's, but i cant seem to find anyone in stock with them.
So just wondering if the Tammiya TRF415 36t pulley's will fit on the diffs?
Old 04-10-2009 | 07:32 PM
  #322
SchuMi2's Avatar
With just a little bit of work they fit fine. Dont forget they have 3mm diff balls.
SchuMi2 is offline
Old 04-10-2009 | 07:38 PM
  #323
SchuMi2's Avatar
This page has the part#'s on it + pics...
http://www.rctech.net/forum/electric...dx-phi-13.html
SchuMi2 is offline
Old 04-15-2009 | 12:16 AM
  #324
prettyinpink's Avatar
hey guys
im out so im selling all my parts for $http://www.rctech.net/forum/australi...50-lot.html250
prettyinpink is offline
Old 04-26-2009 | 11:48 PM
  #325
mazmo's Avatar
Default Phi 2008 diff
Guys,
Recently started using the upgraded "2008" diff. Just a couple of queries.
The diff doesn't seem to move as free as the old, could this be due to the larger diff balls ? ... they seem a tighter fit in the diff gear.
Has anyone tried using the smaller "old" ceramic diff balls ?
Are they any bulid tips recommended for the new diff ?
Cheers
Alan
mazmo is offline
Old 04-27-2009 | 02:41 AM
  #326
E-clip's Avatar
Hi
I have a problem with the layshaft and alloy spur gear holder. The problem is that the Alloy spur gear pulley holder moves side to side and so much that the spur gear spins at of alignment with the pinion gear and then shreads the spur gear ???
All I can find is a whole lot of 5mm washers but does anyone else know what I can use???
E-clip is offline
Old 04-27-2009 | 04:34 AM
  #327
OLD 69's Avatar
Originally Posted by mazmo
Guys,
Cheers
Alan
What grease are you using. Have you run the diff yet? They free up a little once run.
...Ari
OLD 69 is offline
Old 04-27-2009 | 04:36 AM
  #328
OLD 69's Avatar
Originally Posted by E-clip
Hi
Mine has about 2mm play side to side. Its good to have this, helps the belts run in their neutral centre point. Make sure you have your pinion set in the middle of the spur, if this doesnt help shim it up a little.
...Ari
OLD 69 is offline
Old 04-27-2009 | 06:27 AM
  #329
s.nicholson's Avatar
I have used the older ceramic balls with no problem at all, also make sure with your coned washers you have them in this way () as any other way will make the diff bind slightly.
Guys,
Cheers
Alan
s.nicholson is offline
Old 04-27-2009 | 06:30 AM
  #330
mazmo's Avatar
Thanks Simon,
Does type / quality of grease used on diff balls & plates also make a difference ?
mazmo is offline
