SC10 Thread
Old 04-20-2009 | 09:17 PM
  #721
trx450racer174's Avatar
The grinding noise has been a probblem in some trucks. To remedy that take the thin shim from the outside axle cup and move it to the inside of the diff on top of the large shim and then put in the pin and sungear. This has seemed to help the trucks with that problem.
trx450racer174 is offline
Old 04-20-2009 | 09:20 PM
  #722
Crawler's Avatar
Finished mine tonight, just need to paint the body and wait for my electronics to arrive. So far, super smooth build, no issues, no missing parts, and my diff is smooth like butta.
Now I just need to pull the trigger on a color, only have about 20 that I'm trying to choose from.
Crawler is offline
Old 04-20-2009 | 09:22 PM
  #723
BuggyKing's Avatar
We found that you need to add an additional shim behind the moon gear to run tighter gear mesh and will eliminate the grinding.
BuggyKing is offline
Old 04-20-2009 | 09:27 PM
  #724
Come on get creative. And only 20 colors????
Old 04-20-2009 | 09:31 PM
  #725
wow, things starting to heat up on this thread...
They are working great for us here in PDX when the track is wet, when it dries we are struggling to hook up.
Had the diff click, added extra shims - so far, so good. 3 race nights and a whole lot of practice packs. Only thing I've broken was a body mount.
Sure traction is an issue at times, but I'm confident this is just weight and tires...if the track is wet/sticky, slashes don't stand a chance!
Looking for more reports from guys running stock slash tires, one report I read was favorable, anyone else!
Have fun guys and lighten up!
(Those w/ QC issues, AE will take care of you I'm sure, just email them!)
Last edited by w-fly; 04-21-2009 at 10:53 PM. Reason: lost to 2 slashes tonight...had to remove my smack talk
w-fly is offline
Old 04-20-2009 | 09:33 PM
  #726
Double Dee's Avatar
Originally Posted by Rick Hohwart
Setup?
this is the set up i ran
http://67.199.85.166/racing/setups/s..._ocrc_2009.pdf
also used the 3oz led plate under my reedy 5000. battery all the way foward and led all the way back PS 30 caster more turn in. with the wight my car was easer to drive but lap times did not show that it helped. No weight in the nose???? stock tires and foam
Double Dee is offline
Old 04-20-2009 | 09:42 PM
  #727
PT are you running any weight in the nose????
  #728
Crawler's Avatar
I have something in mind, I want to be different.
Crawler is offline
Old 04-20-2009 | 09:44 PM
  #729
Exactly,, Throw some paint in the A/B and get creative.
  #730
Double Dee's Avatar
No
Old 04-20-2009 | 09:46 PM
  #731
Ok thanks
Old 04-20-2009 | 09:48 PM
  #732
Double Dee's Avatar
Ok thanks
Drive it like you are steeling itlol
Old 04-20-2009 | 09:55 PM
  #733
oooooooo dont worry i will, I have another one in a box not put together yet for spares if i break something, My kid wont be to happy but his B-day is still a month away.
Old 04-20-2009 | 09:59 PM
  #734
Double Dee's Avatar
Thats funny I have ran 5 heats 2 mains and 8 reedy 5000 packs and not broke 1 part thats right not 1. but my chassis has a crack and my body is not looking new. lol
Old 04-20-2009 | 10:16 PM
  #735
Where do you get lead plates from? Got any Links?
Jake O is offline
