Team Associated SC8 Setup and Tips >
Old 04-16-2009 | 12:15 PM
  #331
NielsVV's Avatar
Originally Posted by NielsVV
I had some troubles today while I was driving. After 2 or 3 tanks, my servo saver comes loose. The manual says that the gap were the spring is between, have to at least 8,3mm. But mine alu ring is going allways down and he is scrathing against my lower frame, so that my steering servo can't turn anymore.
It isn't easy to describe, and my English isn't that good.
Here are the photo's:
Has nobody any solution for this?
NielsVV is offline
Old 04-16-2009 | 12:44 PM
  #332
dude, the servo saver is adjustable. So if its scratching the chassis just turn the nut, tightening it, so that its not binding.
losifiend is offline
Old 04-16-2009 | 01:03 PM
  #333
K_B's Avatar
K_B
If the servo saver nut is working it's way loose, use thread-locking compound to keep it in place.
K_B is offline
Old 04-16-2009 | 07:27 PM
  #334
bonghitmike's Avatar
some rock guard screen like the real trucks
Attached Thumbnails Team Associated SC8 Setup and Tips-picture-005.jpg   Team Associated SC8 Setup and Tips-picture-006.jpg   Team Associated SC8 Setup and Tips-picture-007.jpg   Team Associated SC8 Setup and Tips-picture-009.jpg
bonghitmike is offline
Old 04-16-2009 | 08:38 PM
  #335
K_B's Avatar
K_B
Pretty cool. Makes putting gas in it a bit more difficult though
K_B is offline
Old 04-16-2009 | 09:17 PM
  #336
My LeDuc version:
Attached Thumbnails Team Associated SC8 Setup and Tips-truck1.jpg   Team Associated SC8 Setup and Tips-truck2.jpg
Six5 is offline
Old 04-17-2009 | 10:14 AM
  #337
sweet truck i just stared to get the stickers to do the same thing. im still looking for the toyo tires sticker that goes where the b f good logo is, and some small other logos. then all i need are some new silver wheels.
Old 04-17-2009 | 10:18 AM
  #338
i have never raced, but if i do i'll take out the side one or just get a new roll cage. i was kinda thinking of getting one to paint so then i could have a "custom" cage.
Old 04-21-2009 | 04:54 AM
  #339
GNS Racing 86's Avatar
just wondering now that these have been run awhile. what diff fluids you are using, im running 10 10 07 front to rear, loose soil
GNS Racing 86 is offline
Old 04-21-2009 | 12:36 PM
  #340
Do you like 10 10 7?
Looking at most of the RC8 setups most people seem to run 7 5 3, or 5 5 5....seems that SC8 would be similar, I'd think 10 in the center would make it diff out real bad in the rear?
I am going to try 5 5 5 next time and see how I like it.
My truck has been working well enough so I haven't felt like changing anything, but now it is in need of some maintenance I think it's about time to experiment myself.
What are you running for shock oil?
Also on a unrelated note, after 6 gallons my Pro28 ate a rear bearing...but the truck hasn't needed a bit of major work or had any breakage...
Wes Briscoe is offline
Old 04-21-2009 | 03:50 PM
  #341
no i dont like the 10 10 7 thats why i was asking lol, do you mean rear looping out under power by diff out than yes it does bad, havent touched the shocks. went to 17 tooth bell ( helped) will lighter center diff help?
i havent raced yet just practice less than a gallon of fuel
Old 04-21-2009 | 03:57 PM
  #342
Well, I'm still to nooby to be messin with shock oil & diff levels. I'm still learning the idle, HSN, LSN, etc. How many of you are running the stock pipe? If not, what do you run, and is there much of a performance gain? I'd like to get a little more speed into this truck if possible.
On a side note - I ran dead straight, WOT, into a tree today and busted both of the lower front bumper mounts. But everything is still intact. This truck really takes a beating, especially in my hands.
Six5 is offline
Old 04-22-2009 | 05:51 PM
  #343
did a mod to my rear fenders. cut them and made it so they could fall off if hit hard or i roll a couple times. they turned out sweet, i think. you cant even tell that there cut when there on. ran them the other day at this track and it was still muddy and wet, they did great and when they got covered in mud they started falling off little by little when i would hit the jumps. and when i run it with no fenders it throws up cool ruster tails.
Attached Thumbnails Team Associated SC8 Setup and Tips-picture-010.jpg   Team Associated SC8 Setup and Tips-picture-011.jpg   Team Associated SC8 Setup and Tips-picture-012.jpg   Team Associated SC8 Setup and Tips-picture-013.jpg   Team Associated SC8 Setup and Tips-picture-015.jpg
Old 04-22-2009 | 07:34 PM
  #344
NITROALM's Avatar
Thumbs up
Hi Here are the ones on the SC8 It really worked well.
Pm Me if you have any Questions
NITROALM is offline
Old 04-22-2009 | 08:57 PM
  #345
Lighter center diff oil should help ... the thicker the center diff fluid, in theory, the more power gets evenly distributed front and rear. The thinner the fluid, the more the front end will get power and the rear will have less, and should cause the rear from swapping out as it will be more drug around by the front. But in high bite the front end might dig in more and throw the rear around.
With a thick center diff you should have a lot of power out the rear which will make it swap ends easier on power....
I am going to set mine up per a good known RC8 setup and see how that works...5 5 5 all the way. I'll post how it works..
