REEDY .21 Nitro Engine
#181
#184
#185
I am in the market for a new engine right now, was looking at the reedy mill and I thought there were supposed to be 2 versions coming out, all I can find is ASC800, the one with the black head. Does anyone know if the other one is on the way?
#186
my lhs told me i may have the reedy in my hands next week. or possibly the week after that.
Anything special i need to know about this engine? I have the ae2035 pipe already and have seen in the set-ups guys are using the p3 or p4 plug. I will be using this in the RC8T... dont see that making a difference but I dunno..lol
thanks,
Anthony
thanks,
Anthony
#188
lorider- the P4 plug has been a great plug in the engine. In very cool temps a P3 may be better but for the remainder of this season outdoors a P4 will work fine. I also ran the engine this weekend with a 97T and it also worked well, great idle and crisp bottom end (not to mention they are $4 cheaper).
As far as run times, I do not cut back my throttle and lean the top like some drivers do to try and get runtime. I run the slide all the way open with a 7mm restrictor and get anywhere from 9:40 to 10:15 depending on track, grip conditions, etc..
#190
i would be more then happy with 9 minutes in a truggy during race conditions.. i have been known to have a slightly heavy finger lol.
I race in Canada and well, its barely above 0 Celsius right now. I was thinking i could use the P3 while the ambient stays low, then when the summer actually shows up switch up to the P4....
#192
scottmisfits- I have only ran the motor with the 2035. It does everything well with that pipe so I haven't felt the need to try and find anything else to run.
Joey- not quite sure how to comment because I am honestly not sure if the motor I am running will be the full on production released version, but from my experience thus far, the power band is a little different but the overall characteristics are similar in that OS engines are known to tune well for novice and pros alike. I have put about 3 gallons through the engine, and it's always been an hour on HSN or LSN from a great tune. The carb doesn't jump around alot which is what OS had a good rep for. One thing I have noticed and confirmed with BT that it was normal was the motor will run a little warmer than a Vspec at optimal power, most people run Vspecs around 220 from what I have seen, and my 121 likes to be around 250-255.
As far as power, the motor is very deceiving, as in it's a smooth motor so at first you think the bottom end is soft, but then you easily clear jumps that you thought may be more difficult. The std vspec may have a little harder hitting bottom but the 121 is a pleasure to drive.
