Team Associated SC8E Thread >
Old 05-01-2017 | 01:42 AM
  #1366
RCWERKZ's Avatar
Let's revive this thread!
Here is my SC8 built from leftover parts from my RC8.2e and RC8T builds. I used the RC8T FT chassis, driveshafts, chassis braces and RC8.2E front and rear FT clips(by clips I mean front complete end as well as rear end). Then ordered the SC8 cage, body and bumpers. Guess the only upgrades are the ones that come with the FT kits. But this thing is solid. Plenty of nasty landings and only had a front skid plate break where it screws into the chassis.
Currently running a 1600kv XMAXX Motor with a Traxxas 8s ESC with dual 3600 mah 4s packs. Was running a 46t spur and 15t pinion. Now I'm using the steel 44t Spur and 18t pinion.
This Truck Absolutely ROCKS! Super Durable and fun. This is my go to bash truck at the moment. Never excited to Love this rig as much as I do. AE knocked it out of the park with this one.
Some footage.
https://youtu.be/V0-hRk_ZQjM
https://youtu.be/5fdf8m0a_LE
RCWERKZ is offline
Old 06-12-2017 | 05:04 AM
  #1367
Hi,
Is it easy to find parts for this model even though it has been discontinued?
Reason im asking , is because im thinking of getting one used.
Ill be using it both for bashing and racing out doors.
Wherr do you buy your parts if you need it? What parts do you often need to change?
Thanks,
rbc626 is offline
Old 06-12-2017 | 06:21 AM
  #1368
RCWERKZ's Avatar
Originally Posted by rbc626
Hi,
Thanks,
Parts are readily available. Since it shares the same parts for a RC8.2.e Buggy and an RC8T Truggy.
Just shim the diffs. It's a tank. I would get the TBone Racing F/R bumpers. The only thing I've broken is the front bumper.
Also maybe get extra CVDs and center driveshafts as they tend to bend.
RCWERKZ is offline
Old 06-12-2017 | 12:41 PM
  #1369
Hi,
Thanks for the tips.
For the cvt and central drive shaft, when ordering parts online, if it is for RC8e/ rc82e, would it fit? Or do i have to watch out for certain part numbers?
rbc626 is offline
Old 06-13-2017 | 10:13 PM
  #1370
Andybellus's Avatar
Hi,
It's a crap shoot in my experience.... I would look up the manuals on AE site and cross reference P/N's to see exactly what crosses over and doesn't.
Andybellus is offline
Old 06-20-2017 | 04:02 AM
  #1371
Im still using stock shocks. What shock oil should i use to replace? Im planning to running mostly on outdoor track that is hard packed?
rbc626 is offline
Old 06-20-2017 | 04:06 AM
  #1372
This thing is awesome to drive!
rbc626 is offline
Old 06-21-2017 | 12:46 PM
  #1373
Hi,
What after market tire/wheelss will fit? That are the tire size for these?
Thanks!
rbc626 is offline
Old 06-23-2017 | 09:00 PM
  #1374
what is a good replacement spring to use for this. I am looking for the part asc89350 but all online stores inlooked at dont stock them. What is a good replacement spring i can use. The reason i am asking is because i SC8e nose dives when I am jumping it. One solution that is suggested here is stiffer spring with heavier oil. Full throttle doesnt affect its flight.
rbc626 is offline
