sidewinder 4600  or 5700 >
Old 02-25-2009 | 12:36 PM
jd267's Avatar
Default sidewinder 4600 or 5700
guys i no the 5700 can only run 2 cell lipos and the 4600 can run 3 cell.... to i think the 4600 on a 3 cell 11.1 should blow away a 5700 on two cell 7.4.....am i right???
jd267 is offline
Old 02-26-2009 | 12:35 AM
Drifting101's Avatar
From BYT (Tested in a RC10B4)
MAMBAMAX TOP SPEED CHART
On 6 cells:
4600kv motor ~ 30mph
5700kv motor ~ 35mph
7700kv motor ~ 45mph
On 2s lipo:
5700kv motor ~ 40mph
7700kv motor ~ 50mph
On 3s lipo:
4600kv motor ~ 45mph
5700kv motor ~ 60mph (BYT note: The 5700kv is the fastest!)
Drifting101 is offline
Old 02-26-2009 | 03:12 AM
happywing's Avatar
The short answer is yes, you are right.
happywing is offline
Old 02-26-2009 | 03:20 AM
But the 5700 can run 3s so why not?
http://www.castlecreations.com/products/cms36-5700.html
Old 02-26-2009 | 04:25 AM
Since CC doesn't recommend the combo - their recommendations are based on a lot of testing, its the esc, Sidewinder thats the limitation.
Heck why are you limiting this to the 5700? Just get the MM and run a 9000.
Duster_360 is offline
Old 02-26-2009 | 06:31 AM
racer1812's Avatar
Super Moderator
Put wings on it and post a video on Youtube!!!!
racer1812 is offline
Old 02-26-2009 | 11:41 AM
jd267's Avatar
thanks guys for you time.... when i asked the qestion i only had 2 sidewinders... and castle said a 4600 with a 3 cell with the right gearing in a b4 will smoke a 5700 on a two cell... 11.4/7.4 more volts more power... but i bought a mamba max yesterday so the table turned..lol i will run my t4 with a 5700 and b4 with a 4600 3 cell with the mamba
jd267 is offline
Old 02-26-2009 | 11:44 AM
jd267's Avatar
On 6 cells:
On 2s lipo:
On 3s lipo:
SO A 4600 ON A 6 CELL 7.2V NIHM IS THE SAME SPEED AS A 2 CELL LIPO 7.4 VOLTS I DOUBT THAT
jd267 is offline
Old 02-27-2009 | 12:21 AM
Dunno I just copy, pasted it off the website
Old 02-27-2009 | 02:39 AM
Default insain
try a 7700 on 3 cell lipo. Talk about fast. I have ran a 7700 on three and it's unreal.
latemodel13 is offline
Old 02-27-2009 | 07:40 AM
racer1812's Avatar
Super Moderator
Probly not but it's not gonna a be HUGE difference. Way to many people think a 7.4 lipo hs a HUGE power advantage over a GOOD NIMH. From what I've seen anyway.
Old 02-27-2009 | 08:22 AM
+1
There are some video's on youtube of the 7700 on 3 cell in a TC. Without the right body you get lift off about 80mph with some great hang time.
Who will be the first to try the 9000 MM on 3 cells ?????
Lazer Guy is offline
Old 02-27-2009 | 06:38 PM
Originally Posted by Lazer Guy
+1
Can any one say shattered rotor?
Old 02-28-2009 | 06:42 AM
The difference is bigger in acceleration/punch than outright top speed in my experience. Generally top speed is fairly low current draw compared to hard acceleration, good lipos are better at higher current draws.
Dave H is offline
