PICCO P9 EVO 2
#139
Kamikaze
You are comming to the Winter Nats will you have items for sale there such as the picco plugs. I just picked up a Mugen from someone I think you know (Brian Nak-----).
One more question there is a ofna starter box I can pick up for a good price see pic is this a good box for my needs.
Mugen MRX4X - Picco P9 EVO2
Kamikaze
#140
Cold: P7TC
Hot: P7TH
Maybe you don't have them in your store, but this doesn't mean they don't exist
And I would recommend GRP or Sirio plugs over original Picco plugs for the simple reason, that Picco plugs aren't the best at this moment, just like Novarossi is also poor quality....
Yes, Picco/GRP/Sirio, are exchangable....
Oh, another reason, they cost way less then Picco....
#141
Ok I found the Sirio plugs at ashford hobbies for 6.75. (1720127)
The GRP plugs I could not find for less then 11.75.
Kamikaze sells the picco plugs for 8.50.
M7h if you know of a better deal please tell us.
#143
Thanks I am going to order a few. I dont understand the statement about the p7th and p7tc I always thought the # indicated the temp.
Then I looked at some Kyosho plugs while I was browsing and found they had plugs markes S09 hot and S09 cold.
Does anyone have experience with the starter box i showed a few columns down will this work for me ofna10250.
#144
Actually, Serpent teamdrivers running the Mega engines last year (like I did), recommended them to me....
About the price for GRP plugs, here in the Netherlands I can buy a set of 5 GRP plugs for 32 Euro, while 1 #7 Picco plug will cost me 9 Euro....
#145
Ok I now have the P9 and I was wondering about a few things.
As this motor was used when I got it I wanted to go thru it (piston and sleeve are new).
I pulled the motor apart and went ahead and replaced the outer bearing since I had one but no matter how much I heated I could not get the inner bearing out (any thoughts). ???
Secong was the head shim it measured .49 does anyone no what the shim would be for 20-25%?
I was told they had it set for 30%.
The motor by the way is in great shape with lots of compression tight fit crank to rod (also have extra rod).
#146
Ok I got the inner bearing out today I guess I did not heat it enough before.
I still am looking for the head shim size.
#147
The best is the following:
Put piston at TDC, and then unscrew the cooling head and headbutton.
Measure the distance from top of liner to top of piston.
Also measure the distance the headbutton goes into the liner.
The difference (head clearance) should be around 0.2mm, but I have seen headbuttons where this distance is 0mm.
Now shim the headbutton, until the head clearance is 0.5 - 0.55mm for 25% Nitro, at sealevel...
#148
i have seen that a lot of ppl take this numbers as standard.[i have seen the same numbers for novas.
but i dodnt think that they will have the same compration.i mean different cc in the buttons.
what do you think?
#149
Nova's are more in the range of 0.6-0.7mm, Picco's are between 0.4 and 0.6....
That is indeed the difference in headbutton volume....
squish??
never heard of that word, in this context.... but if you say so?...
squish??
#150
Thanks M7H for the help I took the head off and measured both the piston to top of cylider and the depth of the button.
The piston to top of cylinder is 3.33mm and the button was 3.14 to equal a .19 clearance so I will need a .31 shim to be at .5.
As you can see the button on my Picco is 3.33 not the .4-.6 you descibed not sure why.
But thanks again.
But thanks again.
