Inferno GT-2 Break-in question >
Old 12-28-2008 | 07:39 AM
Foxxrocket's Avatar
Default Inferno GT-2 Break-in question
This question gose out to those who have the Inferno GT and GT2. The first step states to unscrew the High-end needle 3 turn from closed position. I know there is probably no hidden meaning to it. but I'm not sure if you have to tighten to the closed position first, or if it has been factory set to closed closed position. If you have to tighten it closed, by how much?
Sorry it's my first nitro car.
Foxxrocket is offline
Old 12-28-2008 | 11:28 AM
Winner's Circle's Avatar
Close the high speed and then open in 3 turns. The engine should start and run. I think that my final high speed setting is 2.5 turns out from fully closed however just because 2.5 turns works for me it may not for you due to difference in fuels and elevation.
Get the engine running and after running a few tanks start to slowly (1/8 turn) lean (turn in) the high speed until the car starts to run good. Don't go crazy on the tuning trying to get the absolute max out of the engine until you have about 8 tanks of fuel through it. Also, I had trouble trying to run 30% nitro and found that 20% worked great for me.
Check your gear mesh and make sure it is a deep mesh. I also have my 2 speed shifting early to prevent stripping 2nd gear.
Lee
Winner's Circle is offline
Old 12-28-2008 | 11:43 AM
Foxxrocket's Avatar
Ok, thank you.
Old 12-29-2008 | 12:39 AM
MikaR's Avatar
Lee
Yes, this is a good tip!!
MikaR is offline
Old 12-31-2008 | 02:27 AM
Foxxrocket's Avatar
Another question. I'm planning on getting an OFNA Starter Box for the car. But the flywheel seems a bit deep. Will the Starter wheel be able catch the flywheel?
Old 12-31-2008 | 03:34 AM
I suggest that you get a Kyosho starter box. These are work great for the GT car. I have them in stock if you decide you want to go this route. About the same $$ as an OFNA.
Lee
Old 12-31-2008 | 07:45 AM
Foxxrocket's Avatar
I usually get things cheaper from my LHS than the internet or other shops. And I'm getting it at a good price, so I just wanted to know if it will work on the IGT2. Good price or not, it'll just be one big expensive paper whight if it can't reach the 3mm gap between the chassis and flywheel.
Old 01-01-2009 | 04:34 PM
dude-'s Avatar
Default New IGT2
Hi Guys, what do you guys think. This cars will be given to the next sponsored RC team.
dude- is offline
Old 01-01-2009 | 05:18 PM
Foxxrocket's Avatar
Hey! It looks just like mine. Execpt without holes, and extra stickers.
Old 01-01-2009 | 06:05 PM
dude-'s Avatar
Hey Fox, did you ever get it started? How are these IGT2's. Was the factory setting fine?
dude- is offline
Old 01-01-2009 | 06:25 PM
Foxxrocket's Avatar
No, I just need to get a starter box and Glow fuel. Well, I don't really need the starter box, but it's nice to have in the pit.
