Best .28 engine? >
Best .28 engine?
Best .28 engine?
Old 10-01-2007 | 06:19 PM
  #61
jatoman1992's Avatar
Ninja .28 with JP-1
Picco .28 with JP-2 or 3
jatoman1992 is offline
Old 10-02-2007 | 09:01 PM
  #62
Jason Halvorson's Avatar
the new bad boy on the block is the Go Tech .28!!!!!!!!
Jason Halvorson is offline
Old 09-22-2008 | 10:28 PM
  #63
stsd285port's Avatar
Default best 28
i have the sts d28 5 port in a xtm mammoth st 10.5 lbs. my brother has a jammin jpx 28 in a jammin x1crt 9.5 lbs. my dad has a rex 528x race in a jammin x1crt 9.5 lbs. my sts 28 smokes the jammin and rex from the start to finish. we race in a parking lot with a big strtch and the sts beats them every time no bull.for the money sts rocks.i would have to say sts is one of the best if not the bgest 28. sts slso has the new s28 thats even better so whatch out .
stsd285port is offline
Old 11-24-2008 | 05:46 AM
  #64
drs92's Avatar
sts beating a jpx .28??? Jpx will last longer
drs92 is offline
Old 11-24-2008 | 06:33 AM
  #65
Derek, I sent you a pm back. Listen, if you want a good engine for a cheap price then your choices are very limited. These engines you are looking at are not considered "the best". They will do good but are not the best. There are many factors in this.
The best .28 engines are much more money than what you have looked into.
http://www.carolinasrc.com/Webstore/...idproduct=8838
http://www.carolinasrc.com/Webstore/...idproduct=5184
These are what are considered the best. You also have the Ninja .28 which is top notch. I feel the grp .28 is top of the line at this time.
ABURTON is offline
Old 11-24-2008 | 06:49 AM
  #66
NDHotbodies's Avatar
I have the GRP.21 in my Platinum. went thru one tranny the 1st heat.. I had the slipper too tight tho.. raced the rest of the season with no problems..I personly would'nt put a .28 in a Revo.. a .21 has more than enough power you will need for raceing.. I'm still running the stock plastic gears in my PE..
NDHotbodies is offline
Old 11-24-2008 | 07:04 AM
  #67
sickjamminracer's Avatar
jammin .28
sickjamminracer is offline
Old 11-26-2008 | 07:15 AM
  #68
Mr. Thingdoer's Avatar
Speaking from experience, I'll compile a list
Money is no object (in order)
Ninja MR28
O.S. .28XZ (my favorite, and cheaper to rebuild)
Nova Rossi 528 8 port
Budget
Losi Teal Head 427 (my favorite practice engine, and gives the O.S. an run for it's metal)
LRP Spec 3
Biggest let down ever
Axial 28RR
Mr. Thingdoer is offline
Old 11-26-2008 | 09:31 AM
  #69
tallyram's Avatar
i run a ninja 28 with 1005 pipe in my xt8 and it looks crazy coming down the straight! to much bottom and way to much top, it screams! it pulls very hard all the way through the power band. very smooth for a 28! i know that the jammin/picco 28s are great engines as well, just have to make sure to seal them up good!
tallyram is offline
Old 11-27-2008 | 03:20 AM
  #70
29TC's Avatar
NDHotbodies,
I am thinking of putting a GRP 21 in my Revo PE also. I hope u don't mind me asking, which BB kit are using. What type of gearing and which pipe? Thanks.
Sorry to side track off topic on this tread.
29TC is offline
Old 11-27-2008 | 07:04 AM
  #71
Originally Posted by 29TC
NDHotbodies,
I have the traxxas BB kit.. don't use it tho alot of problems with it, too much flex also..stock gearing that came in the PE and the pipe that came with the promo kit.. great engine. just loosen the slipper alittle,
Old 11-27-2008 | 09:15 PM
  #72
rcaddict02's Avatar
Default peak diablo .28
what about peak diablo .28?????? will it work as a direct replacement on a t-maxx 4908.. or will i have to do some up-grades, how do yall like this motor???
rcaddict02 is offline
Old 11-29-2008 | 09:32 AM
  #73
lethalleigh29's Avatar
has anyone had any problems with the OS xz 28 we have had three guys at our track have major problems with them.
Cracked piston skirt on one.
broken crank on another and sloppy bearing in the other is this normal
Has anyone else had any major problems with these motors.
lethalleigh29 is offline
Old 11-29-2008 | 12:17 PM
  #74
MadRussian's Avatar
Ninja .28
MadRussian is offline
Old 11-30-2008 | 04:18 AM
  #75
no one with any problems with the o.s xz28
i guess it was just a bad batch of engines.
