Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 11-19-2008, 10:07 AM
  #14521
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by STLNLST
I have them in my shocks right now and they seem just fine. I may be switching back to the HB 3 hole pistons for this weekend though.
I was just wondering if anyone had an honest opinion of the durability of the TC? I have been looking at this car but have not run an HPI car since the Pro4 days. What would be the weakest link on the car?
Any input would be appreciated.
artwork is offline
Old 11-19-2008, 02:03 PM
  #14522
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
I've broken steering knuckles the most... But that seems to be pretty common with a lot of cars to be honest. I've broken one arm... but I would have a few of those on hand too. Other than that, I just replace parts when they become worn out, which hasn't been very many so far.
-Korey
Korey Harbke is offline
Old 11-19-2008, 02:16 PM
  #14523
artwork's Avatar
-Korey
sounds very positive...sent you a PM!
artwork is offline
Old 11-19-2008, 02:36 PM
  #14524
ShaunMac's Avatar
It's a good idea to keep some steering blocks, hub carriers, c-hubs and a-arms in your box. These parts usually take the brunt of most impacts. I've broken a few steering blocks, one c-hub, one hub carrier and somehow I managed to break the molded swaybar ball stud off a rear a-arm.
The Cyclone has been a very durable car for the nearly 2 years I have been racing it. The newer TC version should be just as durable.
ShaunMac is offline
Old 11-19-2008, 02:46 PM
  #14525
For me the diffs are the weakest link. Unless you buy the prospec diffs, expect to have diff bolts snapping on you. I even had an AE diff bolt snap the head off.
Stealth_RT is offline
Old 11-19-2008, 03:23 PM
  #14526
Raffell's Avatar
Just wanted to thank some of the local HotBodies Cyclone drivers for participating in the Team Orion Invitational Race November 1st and 2nd at Bending Corners Raceway.
Duy Khoung
Nelson Khoung
Carl Hyndman
Hiro K
Craig Nordstrom
You can check out a few photos of the drivers and BCR at:
http://www.youtube.com/watch?v=2XHqTEt2194
Raffell is offline
Old 11-19-2008, 03:29 PM
  #14527
The one of the best things about the TC kit, is it comes with the Pro spec diff already
-Korey
Old 11-19-2008, 03:32 PM
  #14528
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I plan on seeking revenge on all Tamiya's this weekend. Norcal 416's will feel my pain
Hahahahahahaha
Do work!
BlackedOutREVO is offline
Old 11-19-2008, 03:34 PM
  #14529
rc pete's Avatar
I second the comment on the original diff. The original and titanium screws do snap, usually when you tap something or someone while on power. The pro diff is simply awesome, both in terms of durability and performance... it's waaaaaay smoother.
The only non-stock item I run is the alum steering blocks ... I managed to snap a stock one. Other than that, I'm only down one arm and a hinge pin so far this indoor season.
rc pete is offline
Old 11-19-2008, 04:27 PM
  #14530
[url]
The opposite is true with less rebound. I like less rebound on smoother, longer, sweeping tracks. It seems to make the car more balanced through the long sweepers and such.
-Korey
When would you use rebound foam ???
I see it on some set up sheets.
My fingers are sore right now from getting them all at 75%
Thanks for all the help, You are making me faster and faster with every page on here.
Lazer Guy is offline
Old 11-19-2008, 04:41 PM
  #14531
cyclone x's Avatar
when you giys talk about 75% rebound how do u make the shock do that.
cyclone x is offline
Old 11-19-2008, 07:19 PM
  #14532
RCFREAK's Avatar
Trader Rating: 20 (100%+)
Korey, i just found the silicone tip for the rebound adjusting. Her is one even better, how about finding some "Caster Clip" from another car company. usually from nitro cars. they use them to adjust caster since they use pivot ball suspension. just a thought. then you would have all the same sizes, and unclips rather than taking the shock end off.??? just a thought.
RCFREAK is offline
Old 11-19-2008, 09:29 PM
  #14533
STLNLST's Avatar
Trader Rating: 32 (100%+)
You don't have to take the shock end off using the silicone method.
STLNLST is offline
Old 11-19-2008, 09:36 PM
  #14534
STLNLST's Avatar
The steering knuckles and the ball studs used are crap. Get some titanium (sp) ball studs and stock up on knuckles. It would be nice to be able to buy a pair of knuckles rather than one knuckle and one hub.....but you use to run the pro 4 so I'm sure it was the same back then. Great car though. Where do you plan on getting your parts at???
STLNLST is offline
Old 11-20-2008, 02:44 AM
  #14535
Matt Pocknell's Avatar
Running the same kit from about Feb to now, most weekends racing in mod and 10.5, i think I have slightly bent one driveshaft. All other replacements are due to normal wear (belts, spurs, etc).
Matt Pocknell is offline
