Novarossi engines thread
#2791
#2792
A friend of mine turned down the neck of his Nova carb and made a Teflon insulator. Works great too, but involves a lathe.
Last suggestion is an OS carb, which has an insulator but the diameter is bigger than Nova and Picco. It can be turned down on a lathe as well to fit the Nova crank case.
#2794
#2795
. but they do not shipped overseas
any other's ? thanks
#2797
#2799
where got rich
ask only mah
not buying what
me only got 1 car, use almost 2 years already until COE going to finish liao.. there are much better off people out there, having 3! different cars, few JP's somemore ! now that is a class above the rest
ask only mah
not buying what
#2801
What is the Nova part number for the spring that connects the exhaust pipe to the manifold, 2630 to nova 6 fin conical? The only spring I could find was part #60004 and they are shorter than the ones I got with the manifold...
#2802
he do you know what conrod is the one i must use or the must recommended one for the nova 3sct since i've seen like 4 different ones and none of them says that actually made for the nova 3sct. i'm confused. i know that maybe all those conrods may fit, but i want to know wich one is the original one and where maybe i can get it.
thanks
thanks
#2803
thanks
thanks
This is Novarossi's part's break-down of the engine: http://www.novarossi.com/files/explo...2-3ST_3SCT.pdf
#2805
Not a problem. And I highly recommend buying from Murnan. For engines, engine parts, hop-ups and whatever else he sells, his customer service is the BEST. Just be patient because if there's a big race somewhere, he's probably there racing.
195Likes
