Like Tree195Likes
Novarossi engines thread
Old 08-26-2008 | 07:38 PM
  #2791
jk1152's Avatar
Originally Posted by stefan
The carb of the Picco Evo 3 will fit. It's a composite carb with a plastic insulation around the neck. Works great, not hot starting issues on the Picco.
Thanks, so something like the JLRacing .12 RED DOT EVO3 ENGINE Carb should work on a NovaRossi Plust 12 SCT or 353?
jk1152 is offline
Old 08-26-2008 | 11:15 PM
  #2792
stefan's Avatar
Yep, that's right. You just need to make sure that you get the carb with the black plastic insulator around th neck, which is used on the Picco EVO 3 series.
A friend of mine turned down the neck of his Nova carb and made a Teflon insulator. Works great too, but involves a lathe.
Last suggestion is an OS carb, which has an insulator but the diameter is bigger than Nova and Picco. It can be turned down on a lathe as well to fit the Nova crank case.
stefan is offline
Old 08-27-2008 | 08:43 AM
  #2793
Bad Mika's Avatar
Default 353 tuned...
hi, anyone know where can i get the nova 353 tuned version ? . am quite interested in this engine
many thanks
Bad Mika is offline
Old 08-27-2008 | 08:51 AM
  #2794
wingracer's Avatar
http://ashfordhobby.com/detail.aspx?ID=5919
wingracer is offline
Old 08-27-2008 | 09:06 AM
  #2795
Bad Mika's Avatar
Default ...
Originally Posted by wingracer
hi, thanks for the quick reply . but they do not shipped overseas
any other's ? thanks
Bad Mika is offline
Old 08-27-2008 | 09:15 AM
  #2796
check out rc mushroom
http://rc-mushroom.com/product_info....ducts_id=13369
00VIP001 is offline
Old 08-27-2008 | 06:56 PM
  #2797
Arahawak's Avatar
Originally Posted by 00VIP001
Out of stock and i dun think it the TUNED version.
Arahawak is offline
Old 08-27-2008 | 06:57 PM
  #2798
Arahawak's Avatar
many thanks
You rich hor.. get so many engines.
Arahawak is offline
Old 08-28-2008 | 05:52 AM
  #2799
Bad Mika's Avatar
Default ...
where got rich ask only mah not buying what
me only got 1 car, use almost 2 years already until COE going to finish liao.. there are much better off people out there, having 3! different cars, few JP's somemore ! now that is a class above the rest
Bad Mika is offline
Old 09-10-2008 | 06:16 AM
  #2800
pepsidawg's Avatar
Need pipe suggestions for the ns21p mule motor. Thanks
pepsidawg is offline
Old 09-10-2008 | 09:52 AM
  #2801
JayL's Avatar
R/C Tech Elite Member
What is the Nova part number for the spring that connects the exhaust pipe to the manifold, 2630 to nova 6 fin conical? The only spring I could find was part #60004 and they are shorter than the ones I got with the manifold...
JayL is offline
Old 09-10-2008 | 10:12 PM
  #2802
he do you know what conrod is the one i must use or the must recommended one for the nova 3sct since i've seen like 4 different ones and none of them says that actually made for the nova 3sct. i'm confused. i know that maybe all those conrods may fit, but i want to know wich one is the original one and where maybe i can get it.
thanks
mc_chofo is offline
Old 09-10-2008 | 10:16 PM
  #2803
JetMD's Avatar
thanks
Here you go: http://www.murnanmodified.com/produc...roducts_id=109
This is Novarossi's part's break-down of the engine: http://www.novarossi.com/files/explo...2-3ST_3SCT.pdf
JetMD is offline
Old 09-10-2008 | 10:31 PM
  #2804
well thank u, and i'm laso ashamed that i didn't looked for the exploded view of the engine first at novarossi or at my engines' doc. now it very clear to me. thanks
mc_chofo is offline
Old 09-11-2008 | 04:15 AM
  #2805
JetMD's Avatar
Not a problem. And I highly recommend buying from Murnan. For engines, engine parts, hop-ups and whatever else he sells, his customer service is the BEST. Just be patient because if there's a big race somewhere, he's probably there racing.
JetMD is offline
