M11 and Lipo
Old 07-30-2008 | 10:15 AM
BigRed's Avatar
Default M11 and Lipo
Looking to start using a lipo in my M11. Looking for advice on a pack. I do have an ICE charger, I also have a GFX which I havent sent in for the lipo upgrade. Any advice would be appreciated.
BigRed is offline
Old 07-30-2008 | 02:10 PM
3 cell 2500 mah or higher...
mwry13 is offline
Old 08-05-2008 | 07:11 AM
Bulldawg RC's Avatar
we carry commonsense lipo batteries that fit for the m11.
Bulldawg RC is offline
Old 08-05-2008 | 06:24 PM
abailey21's Avatar
I know of about 5 guys running them locally and most all have the common sense or Maxamps
all 3 cell 2500's
abailey21 is offline
Old 08-06-2008 | 04:40 AM
jla8874's Avatar
I had the Losi 2400 mAh and it was great. One of the few with a balance tap. But if I were to but one today, the best one out right now is the Reedy/LRP VTEC 3000 mAh!
jla8874 is offline
Old 08-07-2008 | 08:41 AM
BigRed's Avatar
Thanks guys. My 2500 nimh just dont cut it. You would think they would hold a charge Has anyone tried using the ICE to charge Lipos? Would it be worth sending the GFX in for the upgrade or just buy a cheap lipo charger w/balancer?
BigRed is offline
Old 08-07-2008 | 08:52 PM
Stevo_Aus's Avatar
Default ICE
I use an ICE to charge my Reedy 5000mah Pro lipo which I use in my touring car. No problems.
I also have a Checkpoint 1030 charger and an Imax B5 charger with balancer built in. The Imax charges in 1/2 the time but doesn't produce the same average voltage (when discharging the lipo) as when I charge with the ICE or Checkpoint (both of which take the same time and produce a similar average voltage out of the battery when discharging).
My gut feel is that the Imax balancer isn't doing a great job but I've just ordered a Hyperion LBA10 balancer to test that theory.
Stevo_Aus is offline
Old 08-08-2008 | 04:25 AM
I'vebeen using my Ice to charge lipos with a DualSky balancer. Has not caused any probs, setup is easy and uses the proper CV/CC protocol. I wanted a second charger and bought a Hyp 0610iNet using that now only because it charges and balances at the same time. Still using Ice when I have a lot of batts to charge.
I use a 3300mah Protek lipo in my Tx, but thats for a 3PK.
Duster_360 is offline
Old 08-20-2008 | 11:10 AM
c0sie's Avatar
Can someone tell me the maximum length in mm of the lipo's you can fit into the M11 please?
Many thanks
Cris
c0sie is offline
