Lipo balancing Question
I just got a reedy 5000 lipo used. I checked the balance with a Track power V-balance unit and it shows the #2 cell had more V than the #1 cell and now It appears to be "balancing" but how long will this take? Its had 3-4 hours total on the balancer yet its still doing the same thing... just blinking on the #2 cell. Im new to using a balancer. Ive had orion 4800's for almost 6 months now and they have always shown to be in balance without ever using a balancer when charging.
I dont have the correct plug to hook up to my charger. I plan to stop by the LHS to get a pigtail made so i can hook this up to my charger and do a balance charge. Maybe this will be faster?
Any advice?
thanks,
Any advice?
thanks,
Got the pigtail I need and did a balance charge. It looked to me like the charger shut off before the cells were balanced. I use an orion Avionics charger and I had it set for 5a (1c). After about 30 minutes of charge I got an open circut error on the avionics. It didn't get to charge end like normal. I have the battery back on the balancer now. Any idea how long i should leave it on the balancer>? It was on at work for almost 8 hours today and it still reads as unbalanced.
Maybe learned the lesson of buying used batteries?
Not familar with your charger, what kind of diff in cell voltage are you seeing? I use an 0610iNet hyperion and when it says balance is over, by the time you disconn everything, theres a small diff in voltages across the cells - maybe 3 or 4 mv, its not perfect.
