Engine stalls
Old 06-05-2008 | 10:40 PM
Default Engine stalls
ok recently went from electric on-road back to my old t-maxx with a O.S. .15 engine. so my problem is that when i manage to get it running and warm it up for a couple of minutes, i give it a little throttle then it stalls. another problem that i am having is that the engine will run for a second then stall. I have recently set the carb settings back to what traxxas suggests for their stock settings and i still have a problem. also when i hit the brakes, it stalls. Help Please!!!!!
Mag-Racer is offline
Old 06-06-2008 | 05:08 AM
GSPOT's Avatar
how is the motor pinch????? does it just sputter and die.....or just stop?
no air leaks in fuel lines or anything?
GSPOT is offline
Old 06-08-2008 | 09:10 PM
i think that it might be the carb, ill just replace it.
Old 06-09-2008 | 07:19 AM
GSPOT's Avatar
carb replacement?...... then its tuning problems
GSPOT is offline
Old 06-09-2008 | 07:52 AM
bobbyblaze's Avatar
engine need tuning ....when you go back to factory settings get it warm up then lean the idle and high speed needle......when you get to the right temp or performance lean the low end needle just a little bit to get that punch when take off just that simple
bobbyblaze is offline
Old 06-20-2008 | 03:08 AM
Red face wow gold
wow goldlineage2 cd keyage of conan goldaoc goldworld of warcraft cd keywow gold
wowgold2008 is offline
HTML code is On
