Engine stalls
ok recently went from electric on-road back to my old t-maxx with a O.S. .15 engine. so my problem is that when i manage to get it running and warm it up for a couple of minutes, i give it a little throttle then it stalls. another problem that i am having is that the engine will run for a second then stall. I have recently set the carb settings back to what traxxas suggests for their stock settings and i still have a problem. also when i hit the brakes, it stalls. Help Please!!!!!
how is the motor pinch????? does it just sputter and die.....or just stop?
no air leaks in fuel lines or anything? |
i think that it might be the carb, ill just replace it.
carb replacement?...... then its tuning problems
engine need tuning ....when you go back to factory settings get it warm up then lean the idle and high speed needle......when you get to the right temp or performance lean the low end needle just a little bit to get that punch when take off:deathstar just that simple:tire::tire:
wow gold
| All times are GMT -7. It is currently 04:06 AM. |
