ICE charger problem
Old 03-17-2008 | 12:00 PM
dgraham225's Avatar
Default ICE charger problem
i bought a new ice charger about a month ago, put a backlight in it, and its been working fine... i was using it this weekend and charged my packs 2 or 3 times, then yesterday when i went to put them on charge again it would give me a output short circuit error, it wouldnt start the charge no matter what i tried...... i took the case down and all looks fine... anyone have any ideas?
dgraham225 is offline
Old 03-17-2008 | 06:07 PM
Alltapdout's Avatar
Were your bannana plugs in correctly? Not trying to be smartazz. If not I'm not sure. Both battery's do the same thing?
Alltapdout is offline
Old 03-17-2008 | 07:33 PM
Does the charger indicate an output voltage on the Data View screen with the battery attached?
Dave H is offline
Old 03-18-2008 | 05:54 AM
dgraham225's Avatar
LOL! i knew that question was gonna pop up... naaa man, i checked, double-checked, and re-checked again over everything i could think of and i had it all correct.
dave h, i will hook it up later on when i get off work and check it out, im not sure really?
Old 03-18-2008 | 03:17 PM
burris7555's Avatar
I recently bought (last week from Tower) a new one and it will not charge at all. It displays a message saying no battery connected. I've tried every Bat. I have and this still comes up. Any ideas?
burris7555 is offline
Old 03-18-2008 | 05:00 PM
Swanny's Avatar
Return it under warranty and get it fixed/replaced.
Swanny is offline
Old 03-18-2008 | 05:09 PM
burris7555's Avatar
I called Tower after I posted that. 2-3 week turn around. Thats BS!!
Old 03-18-2008 | 11:13 PM
air8's Avatar
If your battery has a broken bar or the settings for that size/voltage of battery are set wrong, this message will appear. It has happened to me before. I didn't know what was happening. After messing with the battery I would find loose battery bars. Resoldered it and and started charging. Also I've mistakenly put the wrong profile on for the wrong battery. The charger was looking for a 3 cell lipo and not a 7.2v side x side pack.
air8 is offline
Old 03-19-2008 | 02:52 AM
Wiring probably broke inside.
Try a new harness (banana plugs, wire, and whatever plug you use to charge your batts with).
Sabin is offline
Old 03-19-2008 | 07:54 PM
burris7555's Avatar
You hit the nail on the head! I took the side where the banana plugs, plug into the side of the charger and the Neg. wire was dis connected from the plug in. A little solder fixed the problem, and works like a champ now...
