maxpower engines ?
Old 02-26-2008 | 05:40 PM
  #31
Ryan41's Avatar
Does anyone know where on earth I can buy a Max Power XL3 .12? I'm sick of looking now..cant find them anywhere?
thanks in advance
Ryan
Ryan41 is offline
Old 02-26-2008 | 08:37 PM
  #32
Originally Posted by ma racer
will do captain. thanks. Any clue as to a reference point? The ol XR is worn from only one season of mild to heavy use. temps under control etc. but became hard to use so I took it to a local Max Power sponsored driver and he recomended an internal rebuild. Should I keep the stock shims in place? 30% nitro,,,in Houston no less. Thanks,
Hey MA racer, I would chek the deck height with solder and see where your at first before doing anything with the shimming.After knowing that, you can see if your to high or to low. I sauly run anywher from .021-.024 in my stuff with 30% in Houston. If you need ant help just ask man, no problem.
Scottyoo is offline
  #33
Hey MA racer, I would chek the deck height with solder and see where your at first before doing anything with the shimming.After knowing that, you can see if your to high or to low. I usauly run anywher from .021-.024 in my stuff with 30% in Houston. If you need ant help just ask man, no problem.
Scottyoo is offline
Old 02-26-2008 | 08:39 PM
  #34
thanks in advance
Ryan
You can contact the guys at rc america for all there dealers in your area, They are realy nice guys and will be more than happy to help ya.
Scottyoo is offline
Old 02-27-2008 | 04:15 AM
  #35
RayJ's Avatar
Default Max XL3
To buy: http://nexusracing.net/index.php?cPath=136_151
RayJ is offline
Old 02-27-2008 | 05:27 AM
  #36
ma racer's Avatar
Thanks, Scotty. I'll check it tonight.
ma racer is offline
Old 02-27-2008 | 11:37 PM
  #37
is the following correct?
the SL3 MF and standard version (older max.12) is a torque engine
the newer Xl3 is a rev engine
is this correct? also, is there a MF tuned version of the XL3 out yet?
what are the other differences between the two engines?
TomB is offline
Old 02-28-2008 | 04:40 PM
  #38
Osiris 75's Avatar
From what I was told the SL3 is a long stroke and the XL3 is a short stroke. Supposedly the XL3 only comes tuned from MF!!
Osiris 75 is offline
Old 02-28-2008 | 07:26 PM
  #39
Serpent-Dan's Avatar
Yes the XL3 is Max tuned
Serpent-Dan is offline
Old 02-28-2008 | 08:36 PM
  #40
ok, so it's a rev motor. i was also told via PM on another forum that the piston material is different.
TomB is offline
Old 02-29-2008 | 05:41 AM
  #41
ma racer's Avatar
Scottyoo- deck clearance on the ol XR was .60. But that's a needin to be rebuilt still, p/s/r. I think the rod had a bit too much play, haha ya think?
ma racer is offline
Old 02-29-2008 | 05:59 PM
  #42
tony montana's Avatar
I think brooklyn hobbies has that engine in stock
tony montana is offline
Old 02-29-2008 | 06:09 PM
  #43
I spoke to Richie last week he said no too much$$
Old 02-29-2008 | 06:24 PM
  #44
also brooklyn hobbies are one of the best to deal with
Old 10-09-2008 | 04:55 PM
  #45
Exclamation Max power mx 21 m3
Hi I just got the max power mx 21 m3 , Does anyone know the factory needle settings? I bought it used...Also if the con rod has a little bit of play do i need to replace it? Does anyone know which con rods fit???
XB8TQ is offline
