1/12 forum
Raising BOTH ends of the shock the same amount only raises the center of gravity because you haven't altered the geometry, you've just pushed it further in the air. A vertical shift through addition of a constant in cartesian coordinate linear equation terms where the line is defined by the axis of your shock.
Raising the front of the shock gives more weight transfer to the front on-power and tends to provide more on-power steering.
The closer to the chassis you are with the links and pivots the lower the roll center, raising them raises the roll center. This can be seen with the pre-3.2R Carpet knives "standard" roll-center vs the accessory "low" roll-center kit (which was standard on the 3.2R and now the Gen-X). Raising the roll center gives more side-to-side weight transfer and aids rear traction in low-medium grip situations. This can lead to traction-rolling as grip increases. Lowering the roll-center decreases this tendency to traction-roll by making shift more laterally at the tire contact patch than pushing down (higher roll-center) so the rear will try to break traction (eventually) and slide rather than bite in.
I have CRC tires installed on my gen-x currently. I don't have CRC rear pinks available right now so I'm thinking of putting Prizm pinks on the rear, and dont want to put a different size wheel on to limit the change of variables on my setup. I also heard I have to shim both sides to keep the width the same.
Actually, to answer Smoke's original question. Raising the front of the link creates roll steer by moving the inside wheel forward. This can help with steering in the middle of the corner but can make an already aggressive car very hard to drive. Raising the rear of the link has the opposite effect and is rarely used since the car doesn't want to track correctly in the corner.
Socko
Socko
Sorry but once again, it matters what brand the motor is based on. Team Brood has 19t motors based on Atlas, Trinity Komodo Dragon, Trinity C2, Reedy and maybe others, including the V2 you mentioned. If you can figure out which Brood motor you have someone will be able to help you. I know a good starting rollout for the Komodo on a track like the one you mentioned is 47mm. C2 would be higher. Reedy even higher
2991Likes
