Mad Force Issue >
Mad Force Issue
Mad Force Issue
Old 01-16-2008 | 02:30 AM
steven_tiger's Avatar
Default Mad Force Issue
Hi,
Having a little issue with my Mad Force.
When I put the brake on (reasonably hard to full) the throttle sticks and will not move and hence the truck will not rev or move forward or back.
I have to turn the truck off, turn off the radio gear, and turn it all back on for it to become unstuck.
Anyone know possible causes?
Thanks in advance.
steven_tiger is offline
Old 01-16-2008 | 09:47 PM
wog....supraman's Avatar
so its the servo that sticks, yes?
trial and error is the only way if it is not the servo..........take the ballend off the throttle and open the throttle all the way.....and then close it.......and then see if there is any 'rough' spots in the stroke of the throttle......if that checks out ok....then move on to the throttle servo......and move the servo horn with ur hands (radio off the whole time) and see if it sticks.....it thats ok try it again with the radio on (disconnected from throttle) if it sticks then u have a problem.......find out exactly where it sticks on the servo horn....take the horn off and position it bak on a few splines in the other direction....if u understand wat i mean., then try again and continue adjustin until it doesnt stick anymore...
or u could just replace the servo! standard futaba 3003 servo costs 20 buxs....
good luck
wog
wog....supraman is offline
Old 01-16-2008 | 09:48 PM
good luck
wog
Old 01-17-2008 | 03:21 PM
Thanks for ther reply mate.
It turned out to the the linkage that was sticking.
A few little alterations and some new batteries in the receiver fixed that issue
HTML code is On
