1/12 forum
I have a helios radio and setting up my 12L4 with a hitech servo hs-225mg...and when I go into steering balance it goes all the way to 100% but it still needs more throw....The stops on the knuckles are not close to hitting or even touching for that matter..Anybody got any ideas
Second, not familiar with "steering balance" but are your epa's adjusted correctly. Are you using the servo saver holes closest to the saver/servo mounting screw (shortest possible arm) and/or running a steering block with more than one ball stud hole and you've chosen the hole furthest from the kingpin, or...
I'd rather just use the tube brace and sand it smaller or use the CRC brace and use less shims or o-rings. That would be much easier.
I have a AE 12l4 no manual. I have a few questions.
1. Is there a specific measurement for the center shock.
2.I have all stock stuff, I's running the new JACO PRISMS do I have to get the IRS lowered POD plates and is IRS the only one selling these?
3.What's the fastest 19turn motor (over the counter) available for a long track.
4. I see guys taking motor temps at the track? I understand why however what's considered a "too hot" number?
The cyclone 12 is available right now at Stormer
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61600
http://aedownloads.com/downloads/man...2l4_manual.pdf
Get manual.......
RC mushroom sells them for $249.99. Not too bad. I just wish they would release these in the states. I know they would be a hit. 1/8 scale action at a WAYYY cheaper price. I would get one, it's just I don't think the parts support would be there. Though I do work in a machine shop part time, and could make CF parts if I had to...
2991Likes
