Like Tree2991Likes
1/12 forum
Old 11-08-2007 | 08:18 PM
  #27361
odpurple's Avatar
Originally Posted by scootr117
please do.......I was told to do this to my speedmerchant...
OK, here's a little lesson on cutting down the steering blocks on the old style AE front end.
1. two stock blocks, one with the front tab cut off and a line scribed on the bottom as a cutting guide. I take 1mm off which will allow a 2mm smaller tire to be used on the car. You can do this on a mill or with your dremel, I use a sanding wheel.
2. stock block and cut block ready to install. Make sure both steering blocks are exactly the same thickness or your car will be permanently tweaked.
3. you will have to shorten the kingpin a little on the top or it will hit the wheel (on regular 34mm diameter wheels)
4. You also have to remove a little material from the top front corner of the suspension arm for the same reason.
5. Here's the order in which the parts go together. The two shims on top of the block (in this case the white plastic shim and the metal kingpin shim)have to equal the amount you cut off of the block. EDIT oops! I just noticed that the steering block is upside down in the pic. Don't install it that way! LOL The cut side goes toward the bottom.
continued in the next post
odpurple is offline
Old 11-08-2007 | 08:20 PM
  #27362
odpurple's Avatar
6. Back together
7. On the car
odpurple is offline
Old 11-08-2007 | 09:20 PM
  #27363
AdrianM's Avatar
OD - Do you run your steering links like that? You must have some horrible bump toe in. Get some longer ball studs for your spindles so the steering links don't angle down like that.
AdrianM is offline
Old 11-08-2007 | 09:48 PM
  #27364
odpurple's Avatar
I knew somebody was gonna catch that
Its and older car and one I built before I figured out the bump steer thing, I just used it for the tutorial because it had the old school front end on it. I mostly run the servo angled these days anyway
odpurple is offline
Old 11-09-2007 | 02:14 AM
  #27365
Many thanks OD. I will give it a go.
mark barford is offline
Old 11-09-2007 | 06:08 AM
  #27366
Grenade10's Avatar
OD - Nice instruction on the "Old School" front end!
For us who have been around for a few decades, getting these parts to work has been the "Hobby" side of the sport. I still run the old school on a few cars for carpet. Back a few posts I saw the aluminum reinforcement for the arms. That looked much better machined and engineered from what I had built.
I'm not as proficient on the new style, but with the IRS arms, and some of the CRC parts, maybe it's time to play!!
Grenade10 is offline
Old 11-09-2007 | 11:24 AM
  #27367
Does anyone know where I can get a new JR 3650, I can't find any anywhere?
IMTK422 is offline
Old 11-09-2007 | 11:27 AM
  #27368
Goingfast's Avatar
Originally Posted by mark barford
Hi Guys, does anyone sell lowered old skool front ends?
Hi I've some NIP lower old skool front for sell...pm..Thanks
Goingfast is offline
Old 11-09-2007 | 11:32 AM
  #27369
Carl Giordano's Avatar
Who else besides Novak produces a 19T and stock equivalent brushless motor?
Thanks is advance.
Carl Giordano is offline
Old 11-09-2007 | 12:30 PM
  #27370
scootr117's Avatar
Thanks......off to the mill.........
scootr117 is offline
Old 11-09-2007 | 12:41 PM
  #27371
Try Horizon Hobby at Horizonhobby.com
They are the only ones who sell JR (they own JR)
CREWMAN is offline
Old 11-09-2007 | 12:45 PM
  #27372
J.Gonzalez's Avatar
Carl,
Go with the Orion or Peak motors...come with sintered rotors and go with an lrp speedo if you can. That seems to be the hot combo at rcmadness.
Jamie
J.Gonzalez is offline
Old 11-09-2007 | 12:48 PM
  #27373
odpurple's Avatar
Thanks Those arm braces are from SpeedMerchant. They come anodized blue, and for Carl's car in the pic I removed the anodizing with oven cleaner and polished them to match the other aluminum pieces on the car.
odpurple is offline
Old 11-09-2007 | 01:25 PM
  #27374
Horizon has had the JR 3650 servos on backorder for over three months. That is why I was wondering if anyone new of a LHS or someone that might have one. Thanks
IMTK422 is offline
Old 11-09-2007 | 11:25 PM
  #27375
wallyedmonds's Avatar
you can get them every where in the toronto area.
wallyedmonds is offline
