Hot Bodies Cyclone12 >
Old 11-01-2007, 05:57 PM
  #76
Originally Posted by P2
I already posted all the IIC pics of the car that I have, these are pics of my car. Nothing special
Hey, Pauly!!!
What's up?!? I see you have a Tekin in your car. Have you run it and do you like it? I have one being brought to me at the Reno race this weekend. Was it easy to setup?
s-
Crashby is offline
Old 11-01-2007, 06:11 PM
  #77
P2
P2's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Crashby
Hey, Pauly!!!
s-
Steve,
The FX Pro is very smooth! Set up is the exact same as your B1 (throttle profile 4) and it will be dialed. My B1 is still in my OD12.
Silver & Black 4 life
P2
P2 is offline
Old 11-02-2007, 06:25 AM
  #78
I was thinking of getting one of these cars.
I will be using it for straight line speed.
Will this car be ok in a parking lot that has rocks in it?
Will the rocks get in the diff design?
Are these cars suited to indoor use only?
Car looks hot.
george_georgoul is offline
Old 11-05-2007, 05:04 PM
  #79
Trader Rating: 35 (100%+)
Default parts
anyone know where parts canbe bought for this car? trying to find the new rear aluminum pod plate ......
nazman01 is offline
Old 11-05-2007, 06:30 PM
  #80
P2
P2's Avatar
www.stormerhobbies.com
P2 is offline
Old 11-05-2007, 07:01 PM
  #81
Default 12
stormer has alot, but not the rear pod plate, the hb website says its available btu noone seems to have it
nazman01 is offline
Old 11-06-2007, 03:54 AM
  #82
burbs's Avatar
does this front end fit the other american mounting holes? IE will it fit oter pan cars thanks
burbs is offline
Old 11-07-2007, 06:24 AM
  #83
jdearhart's Avatar
Burbs,
I think I read that "P2" used the IRS lower arms because they were lowered, and the stock arms aren't. So, I'd say yes.
P2,
You have a PM.
Thanks!
Jack
jdearhart is offline
Old 12-16-2007, 12:29 PM
  #84
Trader Rating: 118 (100%+)
ok guys.. have a problem...
with and Orion 13.5 Brushless motor installed.. and running a 42 / 88 pinion/spur... the motor is touching the bottom damper disc plate. Does anyone have an idea of how everyone else is running their brushless motors? Maybe a totally different gear ratio?? Everyone at the track here runs 43/88.. and 43/88 is totally rubbing up against the bottom disc. Any ideas??
Chris Furman is offline
Old 12-16-2007, 12:53 PM
  #85
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Hey, Pauly!!!
s-
Good !
RC MARKET is offline
Old 12-16-2007, 12:54 PM
  #86
RC MARKET's Avatar
which item no. ?
www.rcmarket.com.hk
Old 12-16-2007, 07:43 PM
  #87
P2
P2's Avatar
Try using a smaller spur in the low 70s, then recalculate your rollout.
P2 is offline
Old 12-17-2007, 04:57 AM
  #88
just use a 2mm spacer under the top plate and the middle post. that way you have enough clearance.
omoser is offline
Old 12-24-2007, 11:41 AM
  #89
HB
hi guy´s do i have to put someting under the disks in the middel?
1-12 is new for me thanx
HB is offline
Old 12-29-2007, 01:05 PM
  #90
rosko's Avatar
any set-up sheets available from vegas anywhere
rosko is offline
