Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder ‘B’
King Headz KP-300UL-BLK Front Upper Holder ‘L’
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 09-27-2007, 05:23 PM
  #46
Trader Rating: 29 (100%+)
did you put a picture on post ??
taztal3 is offline
Old 09-27-2007, 07:21 PM
  #47
Michael P's Avatar
later tonight i will post a picture
Michael P is offline
Old 09-27-2007, 07:29 PM
  #48
Ricky Bobby's Avatar
Give C&R Hobbies a call for the best price on the st-rr in stock now
419-483-2096 or 419-512-2682
Ricky Bobby is offline
Old 09-29-2007, 01:33 PM
  #49
i still wait for picture on post
taztal3 is offline
Old 09-30-2007, 03:30 PM
  #50
Michael P's Avatar
Sorry about the picture. My camera is not working I will try to get it working.
Old 10-01-2007, 06:21 AM
  #51
khoo's Avatar
Cool....real cool!!!
http://rcpics.rc-racingcars.com/dive...y/Kyosho-ST-RR
khoo is offline
Old 10-01-2007, 10:21 AM
  #52
Default Blue Springs
Blue Springs are available for the Rear (Also work on Truck front).
IF348-1016
Also a Red spring which is stiffer than the blue for the rear.
IF348-916
Soon we will have the correct size blue spring for the front of the truck.
IS106-816
TRCRacer24 is offline
Old 10-02-2007, 12:25 PM
  #53
Default Parts
New Items for ST-RR / 777 SP2 WC
IF348-1016 Blue Spring (M/L) (Hard)
IF348-916 Red Spring (M/L) (Super Hard)
IF350-716 Blue Spring (S) (Hard)
IF350-1016 White Spring (S) (Super Soft)
IFW338 Hard Spring Servo Saver
IS104 Light Weight Front Center universal shaft (ST-RR)
IS101 Bevel Gear (ST-RR)
IS102 Pinion Gear (ST-RR)
ISD051 Decal (ST-RR)
Available Soon:
IS106-1016 Purple Spring (M) (Soft)
IS106-916 Light Green Spring (M) (Medium)
IS106-816 Blue Spring (M) (Hard)
There may be more items I am missing. I will update when I learn more
info.
Here is a chart on the springs:
White (Super Soft)
Purple (Soft)
Light Green (Medium)
Blue (Hard)
Red (Super Hard)
F.Y.I -
(M/L) = Medium/Long, the medium/long blue springs will work on the
front and rear of the truggy. We will soon have the standard (M)
medium springs in shortly which will be designed for the front of the
truggy.
Old 10-08-2007, 04:10 PM
  #54
Default ST-RR domination
The Kyosho ST-RR dominated again this weekend at the 3rd round of the R/C Pro Series West. The ST-RR went on to TQ and Win in the very capable hands of Cody King. The ST-RR also went out to take all 3 podium spots for the West Division for the series.
Old 10-11-2007, 05:34 PM
  #55
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
how much better is the strr compared with the str?
Ultraspeed84 is offline
Old 10-11-2007, 05:41 PM
  #56
There have been so many improvements to the truck in such a short time. Everything making such a profound difference. They are really two different animals. The longer chassis gives more stability while also allowing more steering because all the extra length is in the rear. Also the Big bore shocks just soak up everything in their path. I would say the pro-drivers have picked up 1-2 seconds a lap and that's a huge amount!!
Old 10-18-2007, 08:40 AM
  #57
Trader Rating: 66 (99%+)
st-rr on the way, I am wanting to run Losi 8t wheels( will run standard buggy hubs) Can anyone share the modding tips for standard size 1/8 arena truck tires to get them to mount properly? thanks a lot Trevor
pwnzor is offline
Old 10-18-2007, 04:04 PM
  #58
Hellsavage's Avatar
Here is a pic of the first ST-RR in my country. I think the man is a sponsored driver by Kyosho and RB. He was by far the fastest on the track but du to a bad accu he became 5th I think.
mzl Hellsavage
Hellsavage is offline
Old 10-18-2007, 10:49 PM
  #59
CRFXXXT's Avatar
Trader Rating: 89 (99%+)
Hey guy's,
Was wondering if everyone is running Losi wheels with this truggy. I just ordered one and wanted to pick up a set or two of tires and wheels but wasn't sure what the story was.
I know the wheels that come with it are standard size, but wasn't sure if people are switching over or not.
Dave
CRFXXXT is offline
Old 10-19-2007, 10:05 AM
  #60
the new Proline LPR's have just been released, hold off for those man, thats what im going to do
pwnzor is offline
