5mm Motor shaft?
5mm Motor shaft?
Is there such thing as an electric motor with a 5mm shaft if so please give me a link!
Andrew
Andrew
Check here
http://www.offshoreelectrics.com/products.php?cat=42
The feigao L motors have a 5mm shaft.
Or here
http://www.rc-monster.com/brushlessmotors.php
I believe all of the Neu motors are 5mm too.
I just bought one of these for my E-Revo
http://www.starluckrc.com/catalog/pr...roducts_id=133
Or here
I ethier need a 5mm motor, or a mod 1 pinion that fitts a normal 540 motor.
I would prefer the pinion becuase it will be alot cheaper any links would be great!!!
Andrew
Andrew
Can you tell me exactly what I need from rc monster?
RcMonster has them listed on that link, as: "1/8" bore Mod1 pinions"
Looks like they are out of stock right now, but usually things aren't out of stock for very long.
There is also a "bore reducer" that you can use to fit a 5mm gear onto a standard 1/8" motor shaft. here:
http://www.rc-monster.com/proddetail...reducer&cat=40
So if you got that, then you can use any Mod1 5mm shaft gear with your 1/8" shaft motor.
Is 1/8th shaft size the normal size of a 540 motor?
Andrew
Andrew
Any one?
