5mm Motor shaft?
Old 09-23-2007, 11:09 AM
Default 5mm Motor shaft?
Is there such thing as an electric motor with a 5mm shaft if so please give me a link!
Andrew
andrewtexas123 is offline
Old 09-23-2007, 11:28 AM
Check here
http://www.offshoreelectrics.com/products.php?cat=42
The feigao L motors have a 5mm shaft.
Or here
http://www.rc-monster.com/brushlessmotors.php
I believe all of the Neu motors are 5mm too.
I just bought one of these for my E-Revo
http://www.starluckrc.com/catalog/pr...roducts_id=133
dway100 is offline
Old 09-23-2007, 11:44 AM
I ethier need a 5mm motor, or a mod 1 pinion that fitts a normal 540 motor.
I would prefer the pinion becuase it will be alot cheaper any links would be great!!!
Andrew
Old 09-23-2007, 11:54 AM
wfdfiremedic's Avatar
http://www.rc-monster.com/gears.php
wfdfiremedic is offline
Old 09-23-2007, 12:00 PM
Can you tell me exactly what I need from rc monster?
Old 09-23-2007, 12:18 PM
glassdoctor's Avatar
RcMonster has them listed on that link, as: "1/8" bore Mod1 pinions"
Looks like they are out of stock right now, but usually things aren't out of stock for very long.
There is also a "bore reducer" that you can use to fit a 5mm gear onto a standard 1/8" motor shaft. here:
http://www.rc-monster.com/proddetail...reducer&cat=40
So if you got that, then you can use any Mod1 5mm shaft gear with your 1/8" shaft motor.
glassdoctor is offline
Old 09-23-2007, 12:54 PM
Is 1/8th shaft size the normal size of a 540 motor?
Andrew
Old 09-23-2007, 02:04 PM
Any one?
Old 09-23-2007, 03:16 PM
ta_man's Avatar
Trader Rating: 154 (100%+)
Andrew
Yes.
ta_man is offline
Old 09-23-2007, 07:16 PM
Yes - 1/8" is normal for a 540 motor. Mike (rc-monster) also sells 5mm to 1/8" bore reducers. If he doesn't have the pinion size you are looking for in the 1/8" shaft size, check the 5mm bore ones and get the bore reducer.
dway100 is offline
