LRP SPHERE COMP. ESC (80700) >
Old 07-19-2007, 11:21 AM
  #571
Joep's Avatar
Here the user guide
Joep is offline
Old 07-19-2007, 11:28 AM
  #572
mangoman's Avatar
Trader Rating: 11 (100%+)
Cheers thanks Joep, i couldnt find it anywhere on the associated/lrp site
mangoman is offline
Old 07-29-2007, 02:08 PM
  #573
jdearhart's Avatar
Trader Rating: 15 (100%+)
Does anyone know where I can pick up one of the TC Spheres? (80750) Everyone seems to be out.
Thanks!
jdearhart is offline
Old 07-29-2007, 04:30 PM
  #574
Trader Rating: 16 (100%+)
Thanks!
If you don't mind dealing with Hong Kong, www.rcMart.com has them. One issue with going that way is that Associated (USA) will not service them.
Still Bill is offline
Old 07-29-2007, 05:53 PM
  #575
jdearhart's Avatar
Thanks for the ifo Bill, but I'd really like to stay in the U.S. I just don't know about buying overseas.
Old 07-29-2007, 09:46 PM
  #576
That's why I added the second sentence to advise you. Wasn't an issue with the LRP I got from them; but, it was a major pain with another brand item that failed on me.
Old 07-31-2007, 07:21 AM
  #577
Trader Rating: 23 (100%+)
Default OK maybe someone has seen this
So I sent in my ESC and they being Associated returned it. It is a 2007 Sphere comp. It ran fine and checked out for htem and then ran 2 good qualifiers and then stopped. What it is doing is after you pull trigger randomly it will stop and the red/yellow lights come on as you pull trigger and it will not enguage the motor brand new 6.5 x-11 untill I rotate the spur and poof will work again until it locks up. So has anyone seen this and what is the issue, because I don't want to sent it back if there is nothing wrong. I am running a m-11 with spektrum a x-11 6.5 turn motor a cap in the esc and the sphere comp. It is very wierd.
-James
Anemic_SluG is offline
Old 07-31-2007, 07:26 AM
  #578
Wild Cherry's Avatar
-James
The red/yellow tell you something is wrong and its purpose is stopping anything worst from happening ...
Your motor would be the first thing to rule out ..
switch it out with another first....
Wild Cherry is offline
Old 07-31-2007, 07:33 AM
  #579
Leodis's Avatar
-James
I have a 2006 Sphere Comp/X-11 6.5 in my truck and I had to turn the throttle exp down to -15% or -20% (can't remember) to get the motor to run smoothly from a dead stop. You might want to try that out before you send it in...
Leodis is offline
Old 08-05-2007, 04:29 PM
  #580
Default meltdown
Has anybody had problems with a motor and speedo melting down at the same time?
AARON YOUNG is offline
Old 08-05-2007, 07:21 PM
  #581
have not seen that yet ...
Esc`s ?
yes...
never seen a melted brushless motor , its usually rotor, bearing`s or sensor...
Old 08-05-2007, 08:19 PM
  #582
Default burnt up
The windings were touching the rotor between the magnets And the speedo all the lights come on but with a new motor it will turn slow then stop.Looks like i will be going to novak.
Old 08-06-2007, 11:21 AM
  #583
retsilla's Avatar
guys, beside e profile diff between sphere and istc ed. wat are e other main diff?
retsilla is offline
Old 08-06-2007, 01:50 PM
  #584
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Guys on the LRP sphere TC
FET servo wire, can I cut it off? with no problems? I have no intestion at all to use a different servo then my futaba s9550... So I dont need a fet wire
Will the TC sphere with a novak motor thermal the motor? Will the TC thermal a LRP x-11 13.5?
BlackedOutREVO is offline
Old 08-06-2007, 05:26 PM
  #585
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
i dont think that the TC spec sphere has a fet wire, mine doesnt, and with the 13.5 i've ran a 4.0fdr to a 3.89 fdr with no thermal issues
Marcos.J is offline
