Like Tree1Likes
Sirio engines thread
Old 06-24-2007 | 02:11 PM
  #2056
EVIL-ET's Avatar
Originally Posted by rc_alan
5 turns from closed on the hsn and 2 1/2 on the lsn should get you in the ball park... From there, you should be able to fine tune your motor...
RC_Alan
thanx for that mate
EVIL-ET is offline
Old 06-24-2007 | 02:30 PM
  #2057
rmdhawaii's Avatar
RC_Alan
What % nitro and plug are you using with these settings?
Thanks!
rmdhawaii is offline
Old 06-25-2007 | 02:29 AM
  #2058
Slo-MTX4's Avatar
Originally Posted by dameetz
So is this normal on Sirio engines? I m trying to find bearings the same size but not OEM. Can anyone direct me? As I said I ve gone through 2 sets already, i replaced it every race because juat after 45mins main the bearing just got too much play and sounded very rough. At the moment I m limiting the usage of my Sti for race finals only.
You will find it very very difficult to find bearings other than OEM. The front bearing is the exact same number as the nova front one but they are different sizes. I complained about my EVO3's along time ago as i was having this exact same problem. And now my STI had done the same.
Slo-MTX4 is offline
Old 06-25-2007 | 04:45 AM
  #2059
dameetz's Avatar
Today i bought a new set of bearings, fortunately the OS TZ's rear bearing is the same size as the Sti however the front one was not the same size so had to buy Sirio's. The OS bearing looks very tight compare to the Sirio. Even when new the Sirio front bearing has got little bit of play. Hopefully this combination will solve the problem. If not I will try the ceramic one that Murnan Mods has on their website.
dameetz is offline
Old 06-25-2007 | 04:48 PM
  #2060
Default Bearing Size
I have an AB modded Sirio S21 BKEVO3 and really liked up until the point the main bearing went (about 2 gallons). Does anyone know the size of the bearings so I can get some ordered? I have checked Kyosho America and they do not list a size or replacement bearing? Thanks for the help!
gtsum is offline
Old 06-25-2007 | 05:11 PM
  #2061
Originally Posted by Sirio2127
Sirio onroad front bearings always leak oil even after 1 start on a brand new bearing I have not realy noiced any bad efects only a small pool of oil after i after run an engine. If people are worried that its realy bad or just dont like the thought change it to a rubber sealed front bearing somthing like a tko front bearing here is there web site. http://tkocompetitiondev.com/shop/index.php?cPath=38_41. they are very good bearings ceramic bearings rb concepts also make a ceramic rear bearing to fit a sirio 21 engine size is ("25.3mm outside dia 14.2mm inside dia and 6mm wide") ive never tryed them but if some one is keen or has tryed one let us know what they last and paform like. Regards Jeremy.
Sorry for my above post (bearing size for s21BKEVO3) I just saw this post - it appears the size for this is the one you mentioned above? Thanks again!
gtsum is offline
Old 06-26-2007 | 01:23 AM
  #2062
Corse-R's Avatar
I m having problem with my Sti 3 ports, its actualy a screamer however i do not like the bearings. From new you can feel that the crankshaft is not tight around the bearings, i have gone 2 set of OEM bearings with mine, has anyone got this problem too? Is there any suggestion on which brand r make should I use rather than OEM?
Look at this:
See their RC Ceramic bearings, got some for my engines and are top-notch, haven't seen anything bad from TKO Bearings. A very nice place to buy things, quick and speedy service, answers very soon at your questions. For sure a great place to buy.
Corse-R is offline
Old 06-26-2007 | 12:38 PM
  #2063
rmdhawaii's Avatar
Does anybody know what the factory settings are for the .12 STI? Yes, I know I can just tune it myself, but I am trying to find this information as a baseline to compare it to what I'm doing.
Thank you
Old 06-27-2007 | 08:18 AM
  #2064
dameetz's Avatar
Aparently the TZ baring does not fit the Sti, Sirio has 22mm outer diameter while the TZ's has 21mm, however the inner is the same 12mm and the width is 5mm. So have to get the Sirio OEM bearing again.
dameetz is offline
Old 06-27-2007 | 08:20 AM
  #2065
dameetz's Avatar
[QUOTE=Corse-R;3430988]Look at this:
See their RC Ceramic bearings, got some for my engines and are top-notch, haven't seen anything bad from TKO Bearings. A very nice place to buy things, quick and speedy service, answers very soon at your questions. For sure a great place to buy.[/QUOTE
Thanks Corse R, will try email them, hopefully the have the sizes.
dameetz is offline
Old 06-28-2007 | 12:39 AM
  #2066
nikoskar's Avatar
Does anyone run the new CL7 On Road?
nikoskar is offline
Old 06-28-2007 | 02:03 AM
  #2067
Default bearing sizes Sirio S27TX
does anyone know the bearing sizes for the Sirio S27TX. I know there part number and that there 7x18 and 14.15x25.45mm but boca bearing needs inner outer and width
treetrunk69 is offline
Old 07-05-2007 | 08:22 PM
  #2068
JMGarrett's Avatar
Default sti
im getting a .12 evo 3 sti , can anyone give me any specs on this motor , or how it performs?
JMGarrett is offline
Old 07-05-2007 | 10:11 PM
  #2069
rmdhawaii's Avatar
Basic specs can be found here:
http://www.kyoshoamerica.com/sirio/
Old 07-06-2007 | 12:11 AM
  #2070
Dynamite's Avatar
have a clean pair of undies ready for after your first race
use josh cyruls break in method, its trick for this motor
Dynamite is offline
