Like Tree1Likes
Sirio engines thread
Old 06-05-2007 | 11:59 PM
  #2041
Sp Racer's Avatar
rmdhawaii....make sure your clutch isn't slipping when it gets hot !
Sp Racer is offline
Old 06-06-2007 | 10:28 PM
  #2042
HarKonnenD's Avatar
Anyone tried this motor against the JLR? Assuming the RB matrix is very much like the Sirio would there actually be any differences. I'm craving something with more bottom end and was told Novarossi is the way to go. I've seen the prices go down for Sirio, but again not sure what route to go. The JLR may be price worthy for performance...but will it have the bottom end I'm looking for...assuming I couple it with the yellow clutch shoe, LW shoes, and soon MSR hard spring?
HarKonnenD is offline
Old 06-06-2007 | 10:57 PM
  #2043
Racing4Evo's Avatar
The gray shoe works best. The JL 12 really is fast. There's not insane bottom like Novarossi or insane top end like Sirio but I'd put it in the middle with power everywhere and very smooth revving like a Honda engine. LOL!
Racing4Evo is offline
Old 06-08-2007 | 07:55 PM
  #2044
HarKonnenD's Avatar
Grey shoe working best in what? I have to say using the yellow shoe compared to the grey was a lot better. I'll keep thinking about what motor I'll go with though as I have lots of options.
Old 06-08-2007 | 08:22 PM
  #2045
HarKonnenD's Avatar
Grey shoe working best with what? I have to say using the yellow shoe compared to the grey was a lot better. I'll keep thinking about what motor I'll go with though as I have lots of options.
Old 06-12-2007 | 01:33 AM
  #2046
maskedrider's Avatar
does anyone here had tried the new sirio pipe which the stringer is shorter and thicker ?
any different compare the pervious model ?
thanks
maskedrider is offline
Old 06-15-2007 | 11:11 PM
  #2047
rcabj's Avatar
Default sirio plug
sorry if this has been ask b4 besides the sirio plug , can other plugs be used with sirio...thanks ( its for the STI)
rcabj is offline
Old 06-15-2007 | 11:17 PM
  #2048
Racing4Evo's Avatar
O.S. plugs can be used.
Old 06-15-2007 | 11:18 PM
  #2049
Racing4Evo's Avatar
Gray shoe, MSR spring, 1.1mm
Old 06-15-2007 | 11:26 PM
  #2050
rcabj's Avatar
tqvmmind i ask u what u think of the STI??
rcabj is offline
Old 06-23-2007 | 06:03 AM
  #2051
dameetz's Avatar
Default Bearings problem
I m having problem with my Sti 3 ports, its actualy a screamer however i do not like the bearings. From new you can feel that the crankshaft is not tight around the bearings, i have gone 2 set of OEM bearings with mine, has anyone got this problem too? Is there any suggestion on which brand r make should I use rather than OEM?
dameetz is offline
Old 06-23-2007 | 05:28 PM
  #2052
wallyedmonds's Avatar
iv noticed this too with my evo 3
wallyedmonds is offline
Old 06-23-2007 | 09:27 PM
  #2053
dameetz's Avatar
So is this normal on Sirio engines? I m trying to find bearings the same size but not OEM. Can anyone direct me? As I said I ve gone through 2 sets already, i replaced it every race because juat after 45mins main the bearing just got too much play and sounded very rough. At the moment I m limiting the usage of my Sti for race finals only.
dameetz is offline
Old 06-24-2007 | 01:32 AM
  #2054
EVIL-ET's Avatar
this has probably been asked before does anyone have the factory needle settings for .12 evo 3 sti.
thanx
EVIL-ET is offline
Old 06-24-2007 | 03:09 AM
  #2055
thanx
5 turns from closed on the hsn and 2 1/2 on the lsn should get you in the ball park... From there, you should be able to fine tune your motor...
RC_Alan
rc_alan is offline
