Sirio engines thread
#1966
Originally Posted by tenderfoot57
Hey guys I have a quick tuning question for ya. I am running a sirio sti .12. The thing has crazy fast top end but I am getting beat out of the bottom. I am running the sirio pipe and the sirio #7 plug, 30% nitro, rrr with 15t and 61t 1st gear. I have tightened my cluth about as far as I dare without sacrificing performance and I am still getting beat out of the hole. The engine runs all day at 246-248 degrees F. I noticed if the engine idles for more than 10 seconds that it would not respond when I gave it full throttle. What I mean by this is that when I pull the trigger the engine continues to idle for another 3-5 seconds before it responds once it responds and clears out it continues to run just fine, it is just a step slow coming out of the corner. I don't know if it is lean or rich on the bottom or do I need to go back to the Nova to get the bottom end that I need. Thanks for the input.
TF
TF
#1967
Originally Posted by RC=Realy_Costly
would u advise running this with an evo3 sti?
is there a difference in preformance?
#1971
Originally Posted by EVIL-ET
is the skyline vr12-plus pipe any good with the sirio .12 evo 3 sti
thanx
thanx
A lot of racers prefer it over the Sirio 2611.
#1972
I have an issue with my sti..
I cant keep the motor in tune.. I think the plug was going out.. when I changed it... the motor ran hot. not over 250. but the motor really is acting up. I took the motor out..
Anyone have tips for tuning.
I cant keep the thing running at a decent idle... I have to run it fast to keep it alive.
I am going to break in my new motor.. I just dont want the same issuses
If I need to replace anything. what do you think it would be.? It seems to have good compression... its still fast but the motor seems to be slow if the temp is not at aleast 220.
#1974
#1975
Originally Posted by nikoskar
Guys what type of motor you prefer.
Sirio STI-T3 or
Sirio STI-T5 ?
Sirio STI-T3 or
Sirio STI-T5 ?
#1976
Originally Posted by twiggy
i don't really think the t5 is that much faster than the t3. if anything, what you gain in speed you will lose in fuel mileage. i don't think the 5port is allowed to run at sanctioned events.
#1977
Thanks a lot Twiggy.In our country the 5Port is allowed at local races.I see the T3 running at the track and was really fast.But the 5port was just arrived from our local distributor.What exhaust do you prefer for tight tracks?Is there Conical pipe for .12 as there is for .21 Sirio engines?
evn on tight tracks and open tracks. i usually play with gearing.
1Likes
