Like Tree2991Likes
1/12 forum
Old 12-17-2006 | 12:24 PM
  #22591
Originally Posted by odpurple
It's nice to have friends
does this mean I should throw your car into the pits instead of handing it to you after a race?
smojoe is offline
Old 12-17-2006 | 12:34 PM
  #22592
odpurple's Avatar
whatever gets it there.
but you'd better watch out, I could fall off of the driver's stand and squish you like a bug, Grasshopper!
odpurple is offline
Old 12-17-2006 | 12:40 PM
  #22593
even if you fall twice as fast as you walk I would still have plenty of time to get out of the way
smojoe is offline
Old 12-17-2006 | 02:17 PM
  #22594
Marcos.J's Avatar
Super Moderator
Originally Posted by protc3
got a report from marcos,his car is still in one piece.
yeap one piece nothing broken! it just wants to launch everytime that I get on the power I turned down the expo and its little easier to drive,
Marcos.J is offline
Old 12-17-2006 | 02:27 PM
  #22595
protc3's Avatar
how did the wheelie bars work
protc3 is offline
Old 12-17-2006 | 02:28 PM
  #22596
Marcos.J's Avatar
Super Moderator
lol
they worked great!! Thanks BMI!!!
Marcos.J is offline
Old 12-17-2006 | 02:55 PM
  #22597
od.you are 100 % correct but dont you feel that the center screw makes the car kinda squirly in the bumpy areas? it does exactly what you said,i just never liked running it because it makes the T plate so rigid front to rear.
also make sure you have sufficient side dampening.i use 5000 wt 1/8th diff oil on the washers.this will increase front traction and eliminate double steer or push
Hi Jason
what do u mean double steering? and whats the effect running without oil on the washers? thanks
NeRacer is offline
Old 12-17-2006 | 03:14 PM
  #22598
protc3's Avatar
what double steer is is when your front tires bite going into and through a corner and then they let go and the car pushes and then bites in again.it almost looks like a wiggle going through the corner.using side dampening helps this by controling the flex of the T bar or side springs(if you run a link car).it dampens the torsional spring tension of the rear pod contoling the load placed on each of the front tires(how quickly the weight is transferred and returned) going into and through a corner.too heavy dampening will overload the front and cause the car to drill its nose to the ground.this is easy to see because you will actually see the inside rear tire lift going through the corner.this adjustment allows you to balance front and rear traction
protc3 is offline
Old 12-17-2006 | 03:18 PM
  #22599
protc3's Avatar
no oil on the washers will give you minimal front traction and maximum rear traction.
protc3 is offline
Old 12-17-2006 | 03:43 PM
  #22600
Default IRS centre shock
Has anyone that has run a new IRS centre shock (very nice shock btw) changed their setup when compared to a std AE one.
I didn't really notice when i built it, but with the same oil as std, the damping is a lot "softer". Not 100% if that is just because the package is smoother as a whole.
I ask, as i was struggling with my car this weekend - and really couldn't put my fingure on why. Changed EVERYTHING back to how it was last time i ran, and car felt spot on again. I've just got this feeling that the difference could be the different feeling of the centre shock.
MattW is offline
Old 12-17-2006 | 03:50 PM
  #22601
Marcos.J's Avatar
Super Moderator
hey Jason ,you got pm
Marcos.J is offline
Old 12-17-2006 | 04:00 PM
  #22602
What sort of ride height do people run on thier front? I'm running a kit stock L4 with some minor upgrades such as slapmaster thrust bearing and ceramic diff balls, with threaded front axles.
Tires are Jacos at about 45mm, but im getting heaps of understeer on power. Im guessing its because the front is stuck up in the air like a monster truck..
I'm running on indoor asphalt that has a lot of grip (nitro cars also run there) - red spring would cause crazy grip rolls. Blue seems good, but i'd like to get rid of some of the understeer still...
v0rtex is offline
Old 12-17-2006 | 04:04 PM
  #22603
Originally Posted by THE DARKSIDE
Express North-South Shoot-Out - Horsham R/C
Stock 1/12 A-Main
1 2 Mark Strasnick 38 00:08:09.649
2 1 Mark Smyka 38 00:08:10.101
3 7 Brandon Hess 36 00:08:00.788 - DARKSIDE Mx2
4 3 Jason Schreffler 36 00:08:05.855
5 5 Sal Amato 36 00:08:08.724
6 4 Andrew Smith 36 00:08:12.568
7 8 Ralph Morella 35 00:08:06.754
8 10 Vito Catalfamo 35 00:08:17.924
9 9 Steve Walter 34 00:08:02.362 - DARKSIDE Mx2
10 6 Greg Fangonil 34 00:08:04.119
Darkside Mx2, Coming to an A-main near you........
http://www.darksidems.com/images/pic..._Side_View.jpg
this is a darkside kit.
How does it feel when racing in mod clases? I cant imagine racinf with so much weight in front in mod class. what more it looks that cg is quite high.
any one tried this in mod?
blazeblazucki is offline
Old 12-17-2006 | 04:06 PM
  #22604
Marcos.J's Avatar
Super Moderator
what compound tires are they?
Marcos.J is offline
Old 12-17-2006 | 04:34 PM
  #22605
N4S's Avatar
N4S
Hey marcos ..... You dont have a spare transponder you want to sell do you ?
N4S is offline
