Like Tree2991Likes
1/12 forum
Old 07-27-2006 | 02:10 PM
  #19576
SOLOARTIST 702's Avatar
Default hmm
Originally Posted by carkillaii
Will you ready for one
going to look at one 2nite
SOLOARTIST 702 is offline
Old 07-27-2006 | 02:49 PM
  #19577
protc3's Avatar
hey adrian,proto DB12 ready to go brutha.
Attached Thumbnails 1/12 forum-db12-pic.jpg   1/12 forum-db12-pic1.jpg   1/12 forum-db12-pic-2.jpg
protc3 is offline
Old 07-27-2006 | 03:14 PM
  #19578
danjoy25's Avatar
Guys,
I have the IRS spacers coming and a few other bits. I just realised being a newbie that I still need shims to adjust the front end. Would using anytype of washer/spacers be sufficient to do the job.
Can anyone also recommend atleast 3 pinion gears to have using a 72 tooth spur (48 pitch) using a KR 10 double motor?
danjoy25 is offline
Old 07-27-2006 | 03:15 PM
  #19579
rcgen's Avatar
I've only ran 1/12 scale on asphault. I am thinking about running at a carpet track next weekend. Advice on tires would be real helpfull.
rcgen is offline
Old 07-27-2006 | 03:31 PM
  #19580
protc3's Avatar
purple front grey rears,white rears black fronts,double pink front and rear.this is all i usually mess with depending on the motor i run and the amount of traction
protc3 is offline
Old 07-27-2006 | 03:35 PM
  #19581
protc3's Avatar
Originally Posted by danjoy25
Guys,
CRC has nice shims for under the arms from what i was told.the teflon castor shims that come with the kit is all you will need unless you want to upgrade them also to the CRC ones.the kingpin shims usually come with the car but if you need em AE sells them.as far as gearing,we will need your tire size to give you a good ballpark gearing.
protc3 is offline
Old 07-27-2006 | 03:42 PM
  #19582
danjoy25's Avatar
I know i'll get shot but I will be running out of the box tyres . My kit was purchase used so I dont have anything other than whats in the car. I was thinking of using the Tamiya wheel spacers as they comes in 0.5 and 1 mm thickness and are also anodised.
So please suggest the biggest pinion I can run on that setup and then I will buy a few smaller ones for when the tyre diameter get smaller.
danjoy25 is offline
Old 07-27-2006 | 03:47 PM
  #19583
protc3's Avatar
i would grab a 17,18,and 19 tooth pinion.maybe even a 20 for when your tires get smaller.AE has shims that are cheap for the rear axle and are very thin that allow for fine axle center adjustment.
protc3 is offline
Old 07-27-2006 | 05:52 PM
  #19584
Marcos.J's Avatar
Super Moderator
very nice Jason!! I like that motor
I got my DB12 ready too
Marcos.J is offline
Old 07-27-2006 | 05:54 PM
  #19585
protc3's Avatar
thanks dude.im looking forward to sunday
protc3 is offline
Old 07-27-2006 | 05:57 PM
  #19586
Marcos.J's Avatar
Super Moderator
maybe you can break that 40 lap barrier
Marcos.J is offline
Old 07-27-2006 | 05:59 PM
  #19587
protc3's Avatar
i dont think that will be a problem as long as i dont eat the walls.
protc3 is offline
Old 07-27-2006 | 06:12 PM
  #19588
Marcos.J's Avatar
Super Moderator
Marcos.J is offline
Old 07-28-2006 | 06:24 AM
  #19589
rcgen's Avatar
Thanks on the tires. For carpet carpet racing how far do you cut your tires for 19t?
rcgen is offline
Old 07-28-2006 | 06:43 AM
  #19590
purpurite's Avatar
All classes generally run the same tire sizes. For club racing, I start out with 47-48 mm rears and 45 - 46mm fronts. I round the corners of the tires in the lathe, too (I need all of the chunk protection I can get). For big races, most guys are using smaller tires all the way around.
purpurite is offline
