Keyence ESC
Old 05-01-2006 | 12:54 PM
  #601
Default Keyence Exstraight
Originally Posted by AdrianM
Yeah..I just noticed that.
The ExStraight is super simple:
1. Turn it on
2. Push and hold the setup button until the LED start blinking
3. Keep you finger off the trigger and push the Set button once to set neutral
4. Pull full throttle and hold it then push the Set button to set high throttle
5. Push full brake and hold it then push the Set button to set max brake
There is a current limiter dial that should always be maxed out so it dose not limit the current.
There is a Min Brake dial that sets how much initial braking you get. I leave this at zero.
Is it necessary to use the schottky diode supplied with the Keyence Exstraight? What about the 3 capacitors if the motor already has surface mount caps (I use a 2x13 team orion revolution). Thanks.
jawa is offline
Old 05-01-2006 | 01:19 PM
  #602
AdrianM's Avatar
You should run the Schottky Diode or a Novak, KO or Much More Super Schottky device on the ExStraight.
If your motor has caps on it or if you use smaller caps you dont have to use the "Corn Kernel" caps Keyence sends with the unit.
AdrianM is offline
Old 05-01-2006 | 07:50 PM
  #603
Hello AdrianM,
Can you tell me the differences between Straight and Flash ESC's?
The flash kinda looks like a update of my A-07.
Thanks, Terry
br241 is offline
Old 05-01-2006 | 08:07 PM
  #604
AdrianM's Avatar
The Exstraight is a Rapida with all the programming bits stripped off. Think of it as an LRP V6 but about 1/3rd the size.
The Flash is a is an updated A-07R.
AdrianM is offline
Old 05-23-2006 | 01:04 PM
  #605
Default Keyence A07-R
Anybody knows if the A07-R would work with 4 cells?
jawa is offline
Old 05-23-2006 | 02:44 PM
  #606
Hyperform Racing's Avatar
Adrian, I have a Keyence that needs repair. Who do I send it to?
Hyperform Racing is offline
Old 05-23-2006 | 03:09 PM
  #607
AdrianM's Avatar
Schumacher, Inc.
6302 Benjamin Rd #404
Tampa FL 33634
Besure to include you contract information in the box.
Thanks,
AdrianM
AdrianM is offline
Old 05-25-2006 | 12:21 AM
  #608
Thanks. No contract info, I'm going to have to pay for the repairs...
Old 05-25-2006 | 06:01 AM
  #609
Adrian,
For oval applications (stock and 19T) most really dont mess with settings too much. Set it at low Drive Frequency and go. Does the Exstraight have the same Fets and on resistance (0.00023) as a Rapida Pro?
If so then the Exstraight might be a nice cheaper alternative for Oval racers.
erock1331 is offline
Old 07-10-2006 | 07:44 PM
  #610
I bought a keyence dont know which one is it ,, zero extreme or rapida .. but I dont know how to set it up .. all it does it when i push brake on my 3pk it like throttle and when I pull on the trigger it brakes .. its backwards.. can anyone help me on how to setup this esc
Roberto Falcon is offline
Old 07-10-2006 | 07:57 PM
  #611
theisgroup's Avatar
press the setup button once. that will get you to the setup mode. then press and hold setup for 4 seconds. you will now be setting neutral. then hit the right arrow, that will be forward and then hit the right again and that is brake. hit right again and you are back to setup.
your transmitter should now be set.
theisgroup is offline
Old 07-10-2006 | 08:41 PM
  #612
doesnt work
Old 07-10-2006 | 09:25 PM
  #613
Reverse the throttle contol on the transmitter before u try setting up the ESC again. The servo reversing needs to be corrected.
Cheers
viper1 is offline
Old 07-10-2006 | 10:51 PM
  #614
nnick's Avatar
Shop Owner
You can download the manual from here
Nick
nnick is offline
Old 07-10-2006 | 10:56 PM
  #615
DirtyDog3375's Avatar
Could have a faulty set button. I have a similiar issue, I cannot get my Rapida Pro to go into the set menu either.
DirtyDog3375 is offline
