BANZAI Motors
#466
Hey nutfluff maybe like 2-3 sets of tires for each class should be safe.
#468
casper- thanks that will work i think ill run (1) exp.stk, (1) 19t, and(1) mod class. im not sure if to run two class' for the buggy or two for trk.
judi- dawson will be there, i think he'll be out there before me.
#469
Chris, Scott says if you aren't used to running at Hot Rod's, which
how can you be in Kansas, the track is more forgiving with truck than
buggy. Maybe that will help you make up your mind.
Judi
Judi
#470
thanks judi, is it one runs on tires with mod motors?
#471
Tech Prophet
You can get two runs out of a set of tires. 3 in stock. I run panther soft switches which I think last a little longer then tapers. Again my rule of thumb is a set of tires per day. (2 runs) Fronts last a lot longer. As the track grooves up it is actually better for the front tires to get more bald to continue taking away steering.
#472
casper, getting closer to my flight out im tryen to make sure i get as much while im here. i dont know about the tire prices out there but the reds out here are collecting dust on the shelves.
#473
BANZAI CUSTOMERS!!!!!!!!! We will have a full supply of motors and
brushes in the store about the middle of next week for the Shoot-Out.
Co27's, P2K2's, Monsters, KD19t's, and of course our new Banzai
Mod Motors!! If any one still wants the C2's for trucks and torque, give
me a call and I'll see to it those are included.
We'll also have T-Shirts available and stickers!!!!!!
Can't wait to see all of you there!
Judi
Judi
#474
Hey all -
I just got back from HRH to signup for the shootout and buy tires ($300 worth...yikes) I took a pic of the blueprints for layout that's going in...shall I post it on here or give it to you all if ya PM me???
#475
post it
#476
POST IT!!
#477
If Mom says so!!!
#478
JEREMY HASE!!!!!!!!!!! I saw you in here, can you finally post??
#479
Does Jeremy Hase know how to post?
#480
Well, he knows how, he just hasn't been able to since he
registered. He's had the same problem I had when I couldn't
post either.
Actually, I think you had that problem too, didn't you Ryan?
Hey Nutfluff, thanks for posting the lay-out!!
post either.
