Novarossi engines thread
#1532
Hi i have the chance to buy a nsr12s3 factory tuned motor. Can anyone tell me when they stoped producing this engine.The engine is new in box and a good price. What mods are done for a factory tuned engine? . Not sure whether to go this way or go for the plus 12-3, any help would be good.
Thanks Paul
Thanks Paul
#1533
Thanks Paul
Thanks Paul
novarossi tuned versions have milled crankshaft with silicone insert.....
the sleeve has some work on exhaust port
and the piston/sleeve set is specially selected.....
#1535
Today I have break in my new Novarossi Plus 12-3. The performance of the engine is very good, but i have problem when the engine is off. I run it with 100 degress and when the engine get off and i want it to turn off it needs to long. the caburetor is too hot.
#1536
Originally Posted by SalvadoriRacing
this engine is still produced........
#1537
#1538
i want to buy a new engine and cant chose witch one to buy can some one help its between a Murnam moded plus 12-3ct at $389(USD) or the JP moded verson at $410(USD) any info that would help me decide would be great
#1539
#1541
There are two orings that are used to seal the carb on the nsr 12 s3.one slips on the barrel of the carb and the other mounts in the crank case at the bottom of the carb barrel.I am looking for the one thats sitting in the crank case. rc mushroom has orings but nothing for the lower or upper carb barrel oring.any help would be greatly appreciated .
#1543
I need some help. I have a novarossi tsr12s3. I am having trouble with glow plugs. One plug only lasts about 4 tanks if i am lucky. I have been using novarossi #7 plugs. I am using trinity monster horse power fuel. 20% nitro 18% oil. On one of the bad plugs i noticed that the wire was like cut. Almost like someone cut it with a pair of wire cutters. I havent had any part of the coil fall into the engine though and it was only one plug that was damaged. On the other plugs there were black residue on the tips that wiped off very easily with a finger or towell.
As for head shims, i only have the aluminum one which is .3mm like stated in a previous post on this thread about running 20% nitro. Should I add another .1mm shim or is it something else?
#1544
Adding a 0.1mm shim could be beneficial because if you're racing near the sea level with lots of humidity you need to make room for that extra humidity on the combustion chamber.
#1545
I will check the con-rod tonight for signs of wear. What would i be looking for exactly? Stretched? I am near sea level too, so if the conrod looks good i will add another shim and give it a try.
195Likes
