Novarossi engines thread
#1502
Originally Posted by markoshark
I have a Novarossi TSR12S3, and was wondering if anyone knew the default carb settings for it?
i did it yesterday
i used a material i found here, it is like thin silicone but is used for sealing pipes, it can "survive" in high temperatures and under any fuel contact
the engine improved the way it is working, although it doesn't drop the RPM immediately after you return the throtle to idle position, it takes some time less than before. Also the temperature of the engine droped some degrees C.
today (i think..) i will receive the o-rings for the tuning niddles in the engine so i will replace them too.. i have this will seal the engine totaly.
thnx for your help
#1504
Originally Posted by jaykay
what kind of exhaust system do you use on a long stroke engine?
i´m going to buy me the new NOVAROSSI PLUS 12-3 and it´s a long stroke engine.
Schreib mir doch mal eien PM wenn du den Motor gefahren bist, würde mich sehr interessieren wie der so geht.
Ach ja, und wo kriegts du den Motor her und für wieviel?
Gruß, Stefan
#1506
Originally Posted by 4racer
hi stefan,
hast du noch was an deinem motor gemacht.
wir haben 2 jungs die hatten schon keine kompression mehr
nach ca. 3 liter.
dieter
sorry guys for writing in german
nach ca. 3 liter.
dieter
Ich habe meine eigene Methode die microcasted Motoren einlaufen zu lassen und die hat sich hervoragend bewährt. Meine ersten beiden haben auch sehr bald Kompression verloren, nun nicht mehr.
#1507
Also, can someone plz shed some light on how Plus12-3 compare to OS speed 12 TZ tuned?
#1510
I just received a Novarossi 2630 pipe and have noticed that the
inlet to the pipe is a smaller diameter than my mugen and max/nova pipe.
2630 fits loosely into my mugen and max/nova header.
Do I need a different header or is it supposed to be loose?
#1511
Originally Posted by stefan
Mielke 2501 mit kurzem konischen Krümmer geht auf meinem R12L3 gigantisch.
Gruß, Stefan
Gruß, Stefan
Ich überleg grad ob der Dieter und ich auch das Mielke 2501 haben. Ich weiß nicht genau welches Habbecke Rohr dem Mielke entspricht
For our english speaking friends:
PM is on his way!
I´m just thinking about if Dieter and I have the Mielke 2501, too. I´m not sure which Mielke Pipe is like our Habbecke one.
#1512
hey all,
do you run your engines under hight external temperatures? these part of the year here we have nearly 40 degrees C, should i protect the engine and not run it? do you have a threshold in air temperatur over which you don't run your engines?
if not is there any measure you take against the high temp?
antony
antony
#1514
Originally Posted by SalvadoriRacing
just put a #8 glow plug and let it go........
do you you change the percentage of nitro in the fuel when the temp rise? i usually run my LL5 with 16% nitro.
195Likes
