Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 05-14-2006 | 07:57 AM
  #1531
HotrodHopkins's Avatar
that's what i use
HotrodHopkins is offline
Old 05-14-2006 | 08:55 AM
  #1532
POOKYT's Avatar
Thanks fellas!!!! Those short palstic jobbers will also help keep the budget in check! Well........Except now I can get the aluminum knuckles and carbon shafts and the kingpins and the .........................
On those short plastic shocks, do they run the same short springs as the other shocks?
Brant
POOKYT is offline
Old 05-14-2006 | 09:09 AM
  #1533
Big Daddy Boomer's Avatar
Brant
I Use the short tamiya springs (not the longer touring car ones part #53440 not these ) part number 53333.
The long ones will work but the short ones let you slam it lower to the ground.
http://cgi.ebay.com/Tamiya-R-C-Touri...QQcmdZViewItem
Boomer
Big Daddy Boomer is offline
Old 05-14-2006 | 09:38 AM
  #1534
POOKYT's Avatar
Boomer
Thank You Boomer!
Brant
POOKYT is offline
Old 05-14-2006 | 09:42 AM
  #1535
tamiyarcracer's Avatar
Brant
Brant I think this is the part number you want. 50746
tamiyarcracer is offline
Old 05-14-2006 | 09:59 AM
  #1536
Could be..... that is what i found quickly on ebay
I was going off of this picture for the springs
Old 05-14-2006 | 11:28 AM
  #1537
Originally Posted by Turbonium
yup... same wheels and tires. although, the alfa is rwd, cooper is front.
Thanks for info.............
Ginsu is offline
Old 05-14-2006 | 02:34 PM
  #1538
BHenderson's Avatar
Regional Moderator
I saw a few pages back where someone said the tamyia connectors for the battery were not the best ones to use. What are you guys using in their place?
BHenderson is offline
Old 05-14-2006 | 02:50 PM
  #1539
deans, use 'em on every car.
  #1540
anyone use these?
http://www2.towerhobbies.com/cgi-bin...?&I=LXRK01&P=7
do they make a difference at all.
Old 05-14-2006 | 02:59 PM
  #1541
Originally Posted by HotrodHopkins
anyone use these?
I do and I think most people do. You won't really notice a difference with the car. It's really one of those little things that add up to alot. Mostly overall weight of the car.
Markus is offline
Old 05-14-2006 | 03:08 PM
  #1542
do you know how much less they weigh?
Old 05-14-2006 | 07:37 PM
  #1543
afrankson's Avatar
anyone use these?
Not sure how much lighter they are, however carbon is much lighter than steel. A lighter drive train component reduces the rotating mass of the drive train which would result in better acceleration and top speed.
I have not installed mine as yet, as such i can't comment on any noticeable difference in performance, however the physics principle supports this.
afrankson is offline
Old 05-14-2006 | 07:55 PM
  #1544
danjoy25's Avatar
Those are mainly for reducing overall weight. They do not rotate with the gears so the rotating mass will still be the same.
danjoy25 is offline
Old 05-14-2006 | 07:56 PM
  #1545
Slotmachine's Avatar
Originally Posted by BHenderson
I saw a few pages back where someone said the tamiya connectors for the battery were not the best ones to use. What are you guys using in their place?
Go Here for great gold plated connectors
Slotmachine is offline
