Like Tree1Likes
RB Engine Thread
Old 02-23-2006 | 03:32 PM
  #91
captian's Avatar
Originally Posted by nefastseven
ok thank you
i run to buy glasses
no biggie with all the eye candy sometimes that happins
captian is offline
Old 02-27-2006 | 02:28 PM
  #92
007kel's Avatar
Default C5 Rody head shimming for 30%
Does anybody know if the C5 Rody is already shimmed for 30% nitro? I heard from one person that it is but the rbproducts FAQ says their 21's are shimmed for up to 25% nitro.
Thanks,
Kel
007kel is offline
Old 02-27-2006 | 02:47 PM
  #93
captian's Avatar
Thanks,
Kel
yes its ready right out the box
captian is offline
Old 02-27-2006 | 03:01 PM
  #94
soc123_au's Avatar
Originally Posted by HarKonnenD
Depends on how ya tune it and run it. Maybe 7 minutes or so
Anyone remember the RB C3? How was its power and performance? I was offered it at my LHS for my Top engine and I'm wondering if it will increase or weaken performance. The only way to know though is to run the top on 30% as is and compare in the future I guess.
The C3 is a weapon, I still have a C3 Rody Worlds engine. It is still a good engine, it now does service in a 1/8 buggy.
soc123_au is offline
Old 02-27-2006 | 09:54 PM
  #95
Xyvern's Avatar
Does anyone know how's the performance of the TM 728 for the monster truck
Xyvern is offline
Old 02-28-2006 | 01:59 PM
  #96
007kel's Avatar
Thanks for the help Captian.
007kel is offline
Old 03-01-2006 | 06:38 AM
  #97
captian's Avatar
no problem you should love in with 30% its got lots of power just untap it
captian is offline
Old 03-02-2006 | 03:25 AM
  #98
Smile
Does anyone knows where to buy 1700-425 engine on the web?
El Buenote BRG is offline
Old 03-02-2006 | 10:03 PM
  #99
SpeedBump57's Avatar
Rody has always stated that the RB's are shimed for 25% from the factory. Some run them this way with 30% and have no ill effects. Most add the shim!
SpeedBump57 is offline
Old 03-03-2006 | 09:56 AM
  #100
Xyvern's Avatar
Bruckner Hobbies
Xyvern is offline
Old 03-03-2006 | 01:13 PM
  #101
Derby Bros Racing's Avatar
WWW.SPEEDWORLDRACEWAY.COM
Derby Bros Racing is offline
Old 03-04-2006 | 05:36 AM
  #102
Smile
Thankyou guys for the info. Very helpful.
Old 03-08-2006 | 09:59 AM
  #103
JAG Racing's Avatar
Default C5 Rody Modified Engine problems
I have a relatively new C5 Rody Modified Engine and while running in a 40 minute race this past weekend the engine decided to suht down and run REAL bad. Engine temps were kept in the 200 - 210 degree range.
Upon inspection - the piston has broken apart near the skirt.
Can I just order the piston since the engine still has tons of pinch? Where to I send the engine to get repaired ?
Is this a common problem?
Thanks in advance!
JAG Racing is offline
Old 03-08-2006 | 02:01 PM
  #104
Thanks in advance!
Contact the Hobby Shop you purchased it from - they should be able to do the repair. If they aren't helpful - contact Kevin @ Ace (650-632-4057), he'll fix you right up. I would get a piston and sleeve set - kinda risky just getting a piston. This isn't a common problem - sucks that it happened.
Rich Browne is offline
Old 03-09-2006 | 07:04 AM
  #105
captian's Avatar
Thanks in advance!
make shore you take your time and brake it in again when you fix it
captian is offline
