Like Tree2991Likes
1/12 forum
Old 01-02-2006 | 07:53 AM
  #16591
Originally Posted by TC4_HALO2_Mark
it was just stock grey rear menganta fronts, it was the Novak lay out at trackside for the novak race coming up next week
Sounds normal. Good luck with that.
Bill
Still Bill is offline
Old 01-02-2006 | 02:54 PM
  #16592
fjm9898's Avatar
has anyone been using the new Jaco 2 stage tires on their 12th?
hat compounds and what do you think?
fjm9898 is offline
Old 01-02-2006 | 03:20 PM
  #16593
Ike's Avatar
Ike
You going to race next Tues. with us Mark?
Ike is offline
Old 01-02-2006 | 03:39 PM
  #16594
B-B
fjm9898, I have used two sets of the 2- stage Jacos. I couldnt really tell any difference over the standard foams. I ran purple front, grey rear I did like the new style rim. This was on a carpet track using TQ Orange. Thanks Bill
B-B is offline
Old 01-02-2006 | 03:43 PM
  #16595
fjm9898's Avatar
jaco doent make a 2 stage rear yet i thought...
fjm9898 is offline
Old 01-02-2006 | 04:14 PM
  #16596
theisgroup's Avatar
they do, but not in gray
theisgroup is offline
Old 01-02-2006 | 04:16 PM
  #16597
fjm9898's Avatar
yea sorry, i know they make a dbl pink rear. but i am pretty sure not a grey
fjm9898 is offline
Old 01-02-2006 | 06:03 PM
  #16598
MATTS's Avatar
Hi guys,
I have a YRX12 but unfortunatly I never race outside, all my racing is on carpet.
I would like to get the AH12 conversion but I am not too familiar with that kind of rear suspension system, is that car conversion recomended for carpet ?
I am also looking at the PRC Quad 12 < that kind of suspension I am familiar with.
Are both good carpet cars ? or ?
Matt.
MATTS is offline
Old 01-02-2006 | 06:43 PM
  #16599
fjm9898's Avatar
well from what i have herd the AH12 my be a bit better on asphalt then carpet. but the Yok Worlds Ed is also on of if not the top asphalt 12th scale. so your car might work pretty well from the start. i think the worlds hass a bit different chassis layout, like the batteries slots moved further from the middle. so if your used to that suspension i would just grab a worlds converson and call it good.
fjm9898 is offline
Old 01-02-2006 | 08:01 PM
  #16600
Switch Blade's Avatar
Looks like we might have 4 people next tuesday
Switch Blade is offline
Old 01-02-2006 | 09:15 PM
  #16601
B-B
fjm 9898 theisgroup is right Jaco does not offer grey in 2-stage . I used the purple fronts with standard grey rears. Sorry for the confusion. Bill
B-B is offline
Old 01-03-2006 | 05:35 AM
  #16602
Default Servo saver?
Which servo saver does everyone run for 12th scale?
I'm running my servo flat and I have an Associated front end.
For some reason the balls hit my servo at extreme right turn.
Thanks in Advance.
r1sportbike is offline
Old 01-03-2006 | 06:09 AM
  #16603
B-B
r1, I think most are using Kimbrough #113. You may have to slightly notch under servo saver if its mounted flat.
B-B is offline
Old 01-03-2006 | 06:26 AM
  #16604
Scottrik's Avatar
Coach always said to wear your athletic supporter...
Though one would think the bodywork would keep such contact to a minimum...
Scottrik is offline
Old 01-03-2006 | 06:51 AM
  #16605
AdrianM's Avatar
Thanks in Advance.
You will never use that much steering throw.
AdrianM is offline
