It goes the wrong way... >
Old 07-30-2005 | 11:56 PM
FALCON-LORD's Avatar
Default It goes the wrong way...
I just replaced the Stearing servo on My E-Maxx with a Hitec HS-945MG. The servo looks to be nice a strong and works quite well.
Except for the fact that when I turn right it goes left, and when I turn left it goes right.
The reading I have done leads me to believe that simply turning the plug around in the reciever is not the answer, and that is the fast way to a dead servo.
So what is the answer?
FALCON-LORD is offline
Old 07-31-2005 | 01:15 AM
miks vones2's Avatar
Smile
your transmitter will have two servo reversing switches. one for throttle, one for steering.
simply put the sterring one in the other position.....easy
miks vones2 is offline
Old 07-31-2005 | 01:48 AM
I have two diferent transmitters, and niether of them have a throtle or stearing reverse switch...
Any other options?
Old 07-31-2005 | 05:14 AM
what radio do you have?
even most low end el cheapo radios have servo reversing
Old 07-31-2005 | 05:59 AM
4wdmt's Avatar
falcon, miks is right. even cheapo Tx have servos reversing on both the steering and throttle. double check it, it might be hidden somewhere, lol.
what are the 2 Tx you are mentioning?
4wdmt is offline
Old 07-31-2005 | 04:23 PM
The TX is the stock one that came with the Maxx.
There has to be a better sollution than tweaking the TX... I mean there must be a way of changing it that is not a "hack" for want of a bretter term, but is a proper "fix"
Old 07-31-2005 | 08:34 PM
Johnathan's Avatar
you should have a reversing thing on your radio, cause i have a E and T maxx, savage,and 3 other cars, and they all have reversing thingamajig swithces. the reversing switches should be at the base of your transmitter of the maxx ( if its the stock 'mitter)
happy racing/driving!
Johnathan is offline
Old 07-31-2005 | 09:46 PM
O.K. I'll have a look when I get home...
This actually leads me to an other question.
3 Channal, Wheel & trigger, AM Transmitters...
Are there any out there?
Old 08-01-2005 | 12:20 AM
O.K. Found teh switches in question.
Thanks for the Assist
Old 08-01-2005 | 12:36 AM
4wdmt's Avatar
I think the only available 3 channel on AM are the ones that goes with most RTR MTs today that has reverse capabilities, like the associated MGT and HPI savage.
4wdmt is offline
HTML code is On
