HPI Nitro Star .12R XS tuning help >
Old 05-31-2005 | 06:20 PM
WeatherB's Avatar
Default HPI Nitro Star .12R XS tuning help
Hey guys,
I've got a HPI Nitro Star .12R XS engine that has been used for about 20 tanks of fuel (including 10 tank break in) and I just installed it on my new R40 and noticed that even though the engine is running rich (lots of smoke) the engine is becoming 240°F (at the glow plug).
I was running a McCoy MC-59 (hot) glow plug and changed it to the MC-9 just now since summer is slowly coming (20°C outside). I haven't tried it with the MC-9 yet but I'm not sure why the engine is running hot even at a rich setting.
I checked the compression and there is plenty.
Any ideas? tnx
WeatherB is offline
Old 05-31-2005 | 07:38 PM
R40Victim's Avatar
I have the same engine/car, and delt with the same problem. Seems that it likes to run a little hot, but with very little oil content. I now run white lightning 30%, and 8% oil. The motor dropped almost 40 degrees, and with tuning, picked up alot of power. I had been using blue thunder 20%. I used the same hot plug. I also switched to a Lola body, basically puting the engine outside the body, plenty of air. I got a new pipe/header(I had been running an old HPI pipe with the rubber coupling), and the temps went down further, and it picked up more power. It's a THS pipe I got from Towerhobbies. So far this has been a pretty good setup.
R40Victim is offline
Old 06-01-2005 | 03:33 AM
WeatherB's Avatar
I think the problem is that I'm running a high oil content fuel (16%).
WeatherB is offline
Old 06-05-2005 | 09:36 AM
factory racer's Avatar
i had sorta the same problem with mine. i also run it in a NTC3 and it ran pretty hot.......i went from sidewinder 20% 12% to white lightning 20% 8% and it is staying steady at about 223* F so its running amazin now....
factory racer is offline
Old 06-05-2005 | 04:27 PM
WeatherB's Avatar
Mine is running around 280°F after racing (temp'd at the glow plug)
WeatherB is offline
