Mini-96 World Challenge >
Like Tree3036Likes
Old 05-10-2026 | 12:55 PM
  #3616
Open classes are open to any body, hard or Lexan.
I have a few lexan bodies, but have found I'm faster with the extra weight of the hard bodies. My Jomu's with lexan wings and roofs come in between 24.5 and 26g and my Lexan bodies are atleast 5g lighter. The extra weight seems to help me roll the corners better, and protect the servo, as I'm a wall rider!😜
it's probably me and my lack of setup experience at the scale with lexan bodies, as they're super fast and responsive with a lexan!
BoxxerBoyDrew is offline
Old 05-11-2026 | 12:55 PM
  #3617
Am i clear, there is no class for black cap brushed motor is that equivalent to the PN 70T brushed?
wakerider113 is offline
Old 05-11-2026 | 01:50 PM
  #3618
The black cap Kyosho Xspeed motor is in Pro Stock (I believe it is a 50T). I've never used a PN 70T but that motor is in the Stock class. I figured things out back when I was getting started mostly by scrolling back through this thread to see pictures of cars and their setups which helped me figure out what classes I could mold the cars I had into.
From the rules:
Stock- Any 4AAA Nimh Chassis , OEM or 70T brushed motor or 3500 & Kyosho 4100kv Brushless motor, Autoscale/White body.
Pro Stock-Any 4AAA Chassis , 48/50T Brushed motor or 5600kv brushless motor, Autoscale/White body.
joelisenat is offline
Old 05-11-2026 | 03:27 PM
  #3619
The black cap x speed motor is, or is very close, to a 50t, making it a ProStock motor. I thought I put it into the updated rules, but I'll double check and correct.
Old 05-18-2026 | 11:12 AM
  #3620
black cap is 50T, but performance are very far away than PN50T (on my club with a 8s track there is .6s gap, easily comparable with Lipo 2500kV) so i think it's closer to the PN70T rather than PN50T, but never tried the 70t, just the black cap and the PN50T, But with the PN, if the car isn't set up perfectly (ball differential and disc dampers), it's uncontrollable
CuriousDolphin is offline
Old 05-19-2026 | 07:02 PM
  #3621
I wonder if the performance of the PN 50T over the Black Cap is like that of the 70T vs. the White cap motor? With the white cap and the same gearing, I have found it's not that the 70T has more top speed, just tons more torque. The 70T can get off of corners faster and recover much more quickly vs. the white cap! I can't test the 50t on a Mini96 as they run out of track before hitting top speed.
I do think on the Mini96 the 50T motors can run with the 5500kv competitively, for me I just like the feel of Brushless after making the switch.
Have Fun and Drive FAST!
Old 05-27-2026 | 06:19 AM
  #3622
The End Of the Month (EOM) IS QUICKLY COMING!!!Have your May CW runs started by midnight on the 31st, and posted before 11:59pm on the 3rd. I will tally and post on the 4th!! THANK YOU ALL for participating!!!Drive Fast and Have FUN!
Old 05-30-2026 | 12:49 PM
  #3623
Class- Box Stock
Date- 2026-04-20
Location- Germany - Eschborn
Race Time- 344.484s 6min 14.484s
Fastest Lap- 4.766
Chassis- MR04
Body- McLaren F1
Wheelbase- 98mm
Tires- F: PN KS 1038; R: Marka V1RR15
Wheels- Stock
Motor- Stock
Batteries- Eneloop white
Front Springs- Stock
T-Plate- PN Spring Steel 4
Motor Mount- stock
Dampener (If applicable)-
Dampener Fluid (If applicable)- 30k
Gearing- 7t
Notes: I fixed my uneven garage floor and things with a layer of plywood. Now it is much better. I did just 626 Laps on this layout, but my last runs after some break were really well, also 63% consistency over 75 Laps. I never had that before. 25Degree Cel. 60% humidity
I still cannot post picture. If demanded i can give them for sure.
BoxxerBoyDrew likes this.
georg.fs is offline
Old 05-30-2026 | 11:44 PM
  #3624
You're good without a pic. If you want to post one, you can on the Facebook page. It usually takes 10 or so posts to be able to post pics here.
Glad ya got your floors leveled and you track is now good to go. Just keep turning those laps and your times will go down and your consistency will go up! If i can do it, anyone can!!😜
Take Care and Have FUN!!!
Old 05-31-2026 | 11:52 AM
  #3625
Default May 2026 Box Stock
Class-Box Stock
Date-5/30/2026
Location-Central NC
Race Time-5:20.695 or 320.695
Fastest Lap-4.088
Chassis-MR-04 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Medium fronts on 20mm RTRC wheels with #1 disk, Marka V1R20 rears
Motor-Stock
Batteries-Reedy 800s
Front Springs-Kyosho Purple
T-Plate-PN G10 Black Fiber Glass #4
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-Changed tires from last time. Only had 4 tries this month and this was at 95.79% consistency and included 3 bad laps (4.871, 4.97 and 5.36).
BoxxerBoyDrew and joelisenat like this.
Traveler2 is offline
Old 05-31-2026 | 11:57 AM
  #3626
Default May 2026 MX-5 Experimental Class
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-5/25/2026
Location-Central, NC
Race Time-5:54.470 or 354.470
Fastest Lap-4.495
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KSK 40 LH fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-GensAce 750s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and is one of the funnest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. Only 1 try this month and 94.86% consistency.
Old 05-31-2026 | 12:02 PM
  #3627
Default May 2026 Stock Class
Class-Stock PNR 3500kv
Date-5/31/2026
Race Time-5:04.247 or 304.247
Fastest Lap-3.853
Chassis-PNR2.5W
Body-Jomurema with PN Lexan Roof
Wheelbase-98mm
Tires-PN KS Firm 20mm fronts, New Marka V1RR15 rears
Motor-PN v4 3500vkv
Front Springs-PN AA Yellow
T-Plate-Kyosho FRP 0.5 Medium
Motor Mount-PN 98mm v5
Gearing-PN 64p 14/53 Ball diff
Notes-Only 3 tries this month and this one was at 96.64% consistency.
Old 05-31-2026 | 05:04 PM
  #3628
ckj
Post May 2026 Box Stock - New racer
Hi, new racer here! Got my mini96 earlier this month and was thrilled to find out about this challenge. Since I'm new I can't add my photos, but here's my first entry:
Class- Box
Date- 5/31/26
Location- San Francisco Bay Area
Race Time- 6:58.927
Fastest Lap- 0:04.990
Chassis- MR-04
Body- Jomureva GT01
Wheelbase- 98mm
Tires- Kyosho
Motor- Stock
Batteries- PN 750 mah
Front Springs-Stock gray
T-Plate- Stock
Motor Mount- Stock
Gearing- 7T
ckj is offline
Old 05-31-2026 | 06:45 PM
  #3629
AM03GT's Avatar
Class- Box Stock
Date- 5/30/2026
Location- Irvine, CA
Race Time- 5:40.856/ 340.856
Fastest Lap- 4.360
Chassis- Kyosho MR04 Rwd
Body- Audi R8 LMS
Wheelbase- 98mm
Tires- FR (PN KSK740) / RR (Marka MZRV1R15)
Wheels- Interlock-6 20mm F0 / Interlock-6 20mm R2
Motor- Stock Silver Can
Batteries- PN Racing 900 mAh
Front Springs- AMA Silver
T-Plate- PN #4 Silver Carbon
Motor Mount- Stock MM
Dampener (If applicable)- Stock Center Shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Notes- KT-531P TX
AM03GT is offline
  #3630
AM03GT's Avatar
Class- Stock
Date- 5/28/2026
Race Time- 5:39.541 / 339.541
Fastest Lap- 4.331
Chassis- Kyosho MR03 EVO (MR04 Front End)
Body- McLaren 12C GT3 2013 (Lexan Roof)
Wheelbase- 98mm
Tires- FR (PN KSM538) / RR (Marka MZRV1R10)
Wheels- Interlock-6 20mm F0 22.2 Disc/ Interlock-6 20mm R2
Motor- PN 3500kv V3.1
T-Plate- PN #4 Spring Steel
Motor Mount- PN Racing V5 (AMA+)
Dampener (If applicable)- AE Damper Tube
Dampener Fluid (If applicable)- 15K (very light application)
Center Shock- AE Center Shock AMA Spring 30K
Gearing- 16T Pinion (PNWC) / Stock MR03 Gear Diff with AMA 64P Spur Mod (53T)
Notes-
AM03GT is offline
