eXcelerate RC Prodigy Formula 1
#833
Don't worry about getting the cars to max width. With our CG and the way the cars work, you don't have to run it in either the front or rear at 190mm. My personal F1 from Champs last year, Alpha, Nats and Canadian Nats was 188mm rear and 184ish front (depending on different brands of tires).
#834
Ball diffs are generally best at matching the wheel speed differences needed during cornering (inside wheel follows a smaller circle than the outside wheel) theoretically scrubbing the least amount of speed of all the rear axle choices. But, ball diffs are heavier, can diff out on high grip tracks, and need to be rebuilt every couple of weekends. Ball diffs are also less expensive than gear diffs. While you are learning, a ball diff will be the easiest to drive at the lowest cost. When I run one on the WGTR, I use 30k Kyosho diff grease to slow down the action so that it acts more like a gear diff. I clean it an apply new grease every two race weekends.
The Gear diff is kind of the middle option. It scrubs a little more speed through rear wheel friction than the ball diff, but less speed than the spool. It rotates well mid-corner, but not as well as the spool. It is capable of stopping the inside wheel spin on throttle off the corner, but without the snap loose effect of the spool. You can tune it to be closer to working like a ball diff by running lighter damping fluid or closer to a spool with heavier fluid. And, they last a long time. I ran the A12 diff for a full season without rebuilding it. The one in my son's car has been in there two full seasons. The negatives are the heavier weight and the overall cost.
My experiences:
17.5 foam on black carpet, spools are fine even in lower grip situations. If my son was still running 17.5, I would have him run the gear diff as he is learning. I would only run it in my 17.5 car if it were a very slippery track.
GT12 rubber tire on black carpet, on a high grip track, the spool is about 0.1 seconds faster for me. On a mid to low grip track, the spool is slower. I will probably run the gear diff in my GT12 car most of the time, except for bigger races with high grip.
WGTR on black carpet, on med to high grip tracks, I prefer the spool. It is a tenth or two faster. On a fresh layout or tracks with low to med grip, I much prefer the gear diff. Or if I show up and am just having an off day and I'm not keeping up with the car. I will put the gear diff into the car. Some days it just isn't worth working that hard and I want an easier car to drive.
You're just beginning. I would say that a gear diff on the F1 car would be a benefit. As for gear diffs failing, they are pretty tough.
#836
I noticed my front wing was drooping more on the rh side so did the boil and got it back flat again. What is your method for boiling wings etc? Start with wing in cold water and let it come to boil? Dunk wing in already boiling water? Take it out and air cool? Let it slowly cool in the water? Is there really a difference in any of that?
#837
#838
#840
1136Likes
