eXcelerate RC Prodigy Formula 1 >
Like Tree1136Likes
Old 11-24-2025 | 04:08 AM
  #841
Originally Posted by mstrfahrenheit
Can anyone explain the difference between the -1.5, -3, and -4 steering blocks?
From our resident expert, MCHamilton:
Steering block offset, or trail, 1.5 or 3, is the number of millimeters the front wheels trail behind dead center of the kingpin. Less front axle trail frees up the car and reduces front traction, improving cornering speed. Less trail is particularly useful high traction black carpet.
empaint3 is offline
Old 11-24-2025 | 05:47 AM
  #842
For the 1/12 car - We have 0, -1.5, -3 and -4. These have 3/16" axle for typical 1/12, Pro10 and WGT Tires.
For the F1 car - We have -1.5 and -3 - These have 5mm axle for F1 tires.
Less trail will generally make the car more responsive off center - more direct/twitchy feel generally. Going further back like a -3 or -4 will smooth the car out off center but will generate more mid/exit steering. Our eXcelerate Prodigy line of cars have seemed to be quickest in most situations with -3 or -4 steering blocks in all classes with the exception of -1.5's in F1 for outdoor asphalt or some driving styles that like a little more response from the front end to find their corner entry. We also use them at times in WGT-R just due to the heavier/higher bodies and roll those cars. -1.5's vs -3 will keep the car more flat mid corner. Hopefully this helps.
Josh Cyrul is offline
Old 11-24-2025 | 07:23 AM
  #843
thank you, josh, this is great. Asphalt and searching for mid/exit steering.
mstrfahrenheit is offline
Old 11-24-2025 | 08:01 AM
  #844
TimPotter's Avatar
Not Josh here, but have you tried tuning with the pivot screws to get your desired exit steering ?
TimPotter is offline
Old 11-24-2025 | 08:05 AM
  #845
Had a really great weekend with the F1 at 45th annual FSEARA race this weekend in Florida. I've had a few practice weekends with the car but this was the first real action against competition, very good F1 class here in FL. Was able to take overall P1 after a good battle in 10 min main.
Some observations:
  • MC Hamilton is an awesome dude and knows this car. I was able to shoot him a few messages here and he gave me few pointers. Thanks so much!
  • You need to spend time on the track running batteries through this thing. There are so many adjustments and you really need to experience the different combos. My final setup sheet is below but really I experimented so much that I this isn't necessarily where I would start for then next race. Put in the time, you will get the output. One of the few cars I've driven that was so responsive to small changes. I could MMs of difference.
  • This car carries a ton of corner speed. It was easily .3/s faster than my F104 and 26 Xray before I even tuned a setup. It's what kept me going through the trials. I knew this would be faster overall once I figured things out.
  • Tires were a struggle. We mostly use team powers or exotek tires here. Top guys all run exo's but they can be a bitch to glue and find the right balance. I def struggled with finding balance. The usual go to is Y rear and Red front, but I could not get the yellows to be stable at all. I ran my fastest laps this way and is what I would usually run, but the car would not have it. I would 360 spin if i let off the throttle too much on the apex of the sweep and sometimes getting too hard on throttle coming out of hairpin. I tried a number of things, but couldn't get it safe enough to trust in a race. Track temps were all over from 90-115F. 14 heats and F1 was the last so the track was greasy and grippy depending on where the shade and cloud cover was. The whole field struggled to find the right tire. I saw R/R, R/RR, Y/Y, Y/R. I went Y/RR for the main. It worked to my advantage as I could drive harder for the first 5 mins until those R came in on the other cars. I paid for it by pushing hard on exit in last 5 mins, but my entry was better and 2nd could never get the edge on me with entry and couldn't make the outside pass stick.
  • Car is very sensitive to ride height changes, especially front.
  • Went too thick on side dampener grease. I need to find a better/faster way to change that. I ran 3 cars and taking things apart to clean out the dampeners was too long. maybe i need to just get a few sets to run
  • i started red springs in front, settled on green. i want to try reds again.
  • only tried black v2 bumps. didnt have clear, oranges i think would numb the steering too much but didn't try. i'm still learning the adjustments here between the bump screw and the front plate screw. I don't have a good handle on flex plate adjustments yet. I got it stable and left it alone. There's tuning here to be had I think but it got to be too much all at once.
In the end I couldn't find a tire combo that gave me both entry and exit the way I wanted. I was still faster than I would have been on my other cars so maybe it's learning to drive this differently, particularly letting entry set up exit better. Red F/Yel Rear was fast and I want to work on getting this stable. I want to see how Joshs new tires will work, looking forward to trying them soon. Exo ball diff worked fine, but did order the new gear diff to give that try and see if that helps with rotation on power/exit. Setup sheet attached.
Still a lot to learn on this car, but big first step forward.
MC Hamilton likes this.
Old 11-24-2025 | 08:06 AM
  #846
i did. I tried 1.0, .75, .50. I landed on .50 but I bet I could make .25 work, just ran out of time.
Old 11-24-2025 | 08:10 AM
  #847
dr_hfuhuhurr's Avatar
Anyone find a way (other than cutting down the pod) to fit a Motiv MC5 motor into the Prodigy F1?
dr_hfuhuhurr is offline
Old 11-24-2025 | 08:15 AM
  #848
robk's Avatar
I have been running that motor since I got the car. What seems to be the problem?
robk is offline
Old 11-24-2025 | 08:21 AM
  #849
The sensor port is hitting the left side pod mount.
Old 11-24-2025 | 08:23 AM
  #850
robk's Avatar
Seems like you're running a lot of camber, with the car spinning off power in the sweeper. Also, why 4 caster?
Running rake in the pivot, like .5 front,, 1.0 rear for example might help the exit steering situation as well.
mstrfahrenheit likes this.
robk is offline
Old 11-24-2025 | 09:33 AM
  #851
TimPotter's Avatar
When changing dampner grease, I split the car by removing both flex pivot screws, remove the dampner rods, spray motor spray in the in the front dampner holes, put a towel over the back so you dont get the exhaust all over. Then take a qtip with some cotton removed and run it down the barrel. Do it a couple times and the qtip comes out clean.
Get some excelerate asphalt tires and get a big smile on your face.
Old 11-24-2025 | 10:19 AM
  #852
yes, re: camber. i went too far with it. i made a big swing so i could feel the reaction. i was going to drop it down to 1 degree but i would up spending most of the time getting ready for my gt12 main (which i podium'd also). its on the list for next practice. I ran .5 most of practice and r1 of qualy. i went 1.5 for qualy 2 and didn't like it. was gonna go down to 1 or .75 but wound up making the quick change to RR on the rear to compensate. i underestimated my changes to gt12 and wound up helping someone else at the same time. and i forgot to eat so i had to pop over to the cafe before i fainted
re: caster. seems counter intuitive to my feedback but because i couldn't get the right feel on exit, i decided to place a bet that with the track getting greasier and 10 mins of overheated tires that i was best served to double down on entry. that turned out to be the right bet cause 2nd couldnt get in better than me. i usually run 9 (or sometimes 12 on the tamiya) caster on my f1, but prodigy kingpins only go to 6. i could probably figure out how to use shims to do a caster split on the plate, but didn't have time to do that experiment. I think ultimately this is my exit issue - im used to the feel of much higher caster. if we ran a 4 or 5 min main i would have stayed at 6. we do 4 min qual and 10 min main so its always a bit of a gamble on gearing and tire temp to get a consistent run.
I hadn't thought about introducing rake in the pivot. that's a really excellent thing to try.
Old 11-24-2025 | 10:32 AM
  #853
MC Hamilton's Avatar
I was using this method but I didn't like having to realign the pivot, o-ring and get it all back into the damper slot. I started removing the four rear pod screws and just flopping the rear end over into the battery tray. So I am leaving the flex pivots and the bottom rear chassis plate all attached.
MC Hamilton is offline
Old 11-29-2025 | 11:20 AM
  #854
Just got my gear diff in. Haven't looked real close at it, but are there some assembly instructions somewhere or is it pretty straight forward? Also, how much oil should be put in? I recall Josh talking about oil weights in one of the threads, or maybe Facebook, so I'll look around some more for that.
empaint3 is offline
Old 11-29-2025 | 12:13 PM
  #855
Disregard, found everything on the website!
empaint3 is offline
